Hello everybody! I am making a steering wheel for games. I have made an another topic similar to this one asking how to implement force feedback. I eventually tried using the JoystickFFB library which does ''work'' but, it's really not that good. Whenever I get into a game with standard force feedback settings it's really jittery and shaky. Whenever I try to let it go to center itself it overshoots and then again it tries to center itself and it overshoots again. I have to center it myself which completely destroys the point of force feedback. I determined the cause is that the JoystickFFB library gives a lot higher value than expected. When I rotate the wheel even 90 degrees the value is at 255(the max value) . The wheel rotates 900 degrees. I am pretty sure the JoystickFFB library calculates it wrong. I tried lowering the voltage and the force feedback from the game and yet it is still shaky and jittery. Are there any other ways of extracting and using force feedback data from a game?
Here is my code:
#include <FFBDescriptor.h>
#include <Joystick.h>
#include "Joystick.h"
//X-axis & Y-axis REQUIRED
Joystick_ Joystick(JOYSTICK_DEFAULT_REPORT_ID,
JOYSTICK_TYPE_GAMEPAD, //JOYSTICK, GAMEPAD, MULTI_AXIS
4, 0, //Button Count, Hat Switch Count
true, true, true, //X,Y,Z
false, false, false, //Rx,Ry,Rz
false, false, false, //Rudder,Throttle,Accelerator
false, false); //Brake,Steering
Gains mygains[2];
EffectParams myeffectparams[2];
int32_t forces[2] = {0};
pinMode(A3, INPUT);
pinMode(9, OUTPUT);
pinMode(10, OUTPUT);
pinMode(13, OUTPUT);
pinMode(7, OUTPUT);
pinMode(6, OUTPUT);
pinMode(4, OUTPUT);
pinMode(3, OUTPUT);
pinMode(12, OUTPUT);
pinMode(A5, INPUT);
//Joystick.setXAxisRange(0, 1023);
//Steering wheel
Joystick.setYAxisRange(0, 1023);
//set X Axis gains
mygains[0].totalGain = 100;//0-100
mygains[0].springGain = 100;//0-100
//enable gains REQUIRED
Joystick.setGains(mygains);
Joystick.begin();
digitalWrite(6,HIGH);
digitalWrite(4,LOW);
analogWrite(9,25);
delay(50);
analogWrite(9,255);
delay(2000);
analogWrite(9,0);
delay(10000);
digitalWrite(3,HIGH);
analogWrite(10,25);
delay(50);
analogWrite(10,255);
delay(2000);
analogWrite(10,0);
digitalWrite(3,LOW);
digitalWrite(13,HIGH);
int value = analogRead(A3);
//set X Axis Spring Effect Param
//myeffectparams[0].springMaxPosition = 1023;
//myeffectparams[0].springPosition = value;//0-1023
//Steering wheel
myeffectparams[0].springMaxPosition = 512;
myeffectparams[0].springPosition = value - 512; //-512-512
//Send HID data to PC
//Joystick.setXAxis(value);
//Recv HID-PID data from PC and caculate forces
Joystick.setEffectParams(myeffectparams);
Joystick.getForce(forces);
if (forces[0] > 0) {
digitalWrite(6, HIGH);
analogWrite(9, abs(forces[0]));
digitalWrite(6, LOW);
digitalWrite(4,HIGH);
Serial.println(abs(forces[0]));
