I have hooked up two bipolar stepper motors like this:
and would like to run this code:
// Drawbot portrait of Erik Satie
// (cc) 2008 AS220 Labs
#include <Stepper.h>
#define motorStepsA 400
#define motorStepsB 400
#define motorPinA1 8
#define motorPinA2 9
#define motorPinB1 10
#define motorPinB2 11
// Approximate number of steps per inch, calculated from radius of spool
// and the number of steps per radius
int StepUnit = 102;
// Approximate dimensions of the total drawing area
int w= 40.5*StepUnit;
int h= 42.5*StepUnit;
// Coordinates of current (starting) point
int x1= w/2;
int y1= h;
// Approximate length of strings from marker to staple
int a1= sqrt(pow(x1,2)+pow(y1,2));
int b1= sqrt(pow((w-x1),2)+pow(y1,2));
// Size of image array
int rows = 31;
int columns = 23 ;
// Radius of pixel circles, in StepUnits
int radius = 40; // equals about .4 inches
// Size of page
int pageW = columns*radius*2;
int pageH = rows*radius*2;
// Size of one "pixel"
int cellW =2*radius;
int cellH = 2*radius;
// Coordinate of upper left corner of page
int page0X = x1-(pageW/2)-400;
int page0Y = y1-pageH-500;
// The image: 0=white, 11=black
char image[] = {
1, 1, 2, 2, 3, 3, 5, 9, 10, 10, 11, 11, 11, 11, 10, 8, 7, 8, 9, 9, 9, 9, 9,
1, 1, 2, 3, 3, 7, 10, 10, 11, 11, 11, 11, 11, 11, 11, 11, 10, 8, 8, 8, 8, 8,
8,
1, 2, 2, 3, 5, 10, 10, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 10, 8, 8, 8, 8,
8,
1, 2, 2, 3, 7, 10, 10, 11, 10, 11, 11, 11, 11, 11, 11, 11, 11, 11, 8, 8, 8, 8,
9,
1, 1, 2, 2, 8, 10, 10, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 9, 8, 8, 8,
9,
8,
1, 1, 1, 1, 8, 10, 10, 10, 10, 11, 11, 11, 11, 11, 11, 11, 11, 11, 9, 7, 7, 7,
8,
0, 1, 1, 1, 8, 10, 10, 10, 10, 11, 11, 11, 11, 11, 11, 11, 11, 11, 10, 9, 8,
8, 9,
1, 4, 6, 8, 9, 10, 10, 10, 10, 10, 10, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11,
9, 8,
7, 9, 9, 9, 10, 9, 9, 9, 9, 10, 10, 10, 9, 7, 7, 9, 10, 11, 11, 11, 11, 11, 9,
2, 7, 9, 9, 9, 7, 5, 6, 8, 6, 6, 9, 7, 3, 1, 2, 7, 10, 11, 11, 11, 11, 10,
0, 0, 3, 5, 0, 1, 4, 5, 4, 0, 0, 3, 7, 3, 0, 1, 4, 9, 10, 11, 11, 11, 9,
0, 0, 0, 0, 0, 0, 0, 2, 2, 0, 0, 2, 6, 2, 0, 0, 3, 8, 10, 10, 11, 9, 7,
0, 0, 0, 0, 0, 0, 0, 0, 1, 1, 1, 2, 1, 0, 0, 1, 3, 5, 7, 7, 9, 6, 7,
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 5, 7, 8, 7, 8, 8,
0, 0, 0, 0, 0, 0, 3, 4, 2, 0, 0, 0, 0, 0, 0, 0, 0, 6, 6, 8, 7, 7, 8,
0, 0, 0, 0, 0, 1, 6, 5, 2, 0, 0, 0, 1, 1, 0, 1, 1, 3, 4, 3, 3, 4, 4,
0, 0, 0, 0, 1, 4, 6, 5, 3, 3, 1, 1, 1, 2, 2, 1, 2, 3, 3, 4, 4, 5, 5,
0, 0, 0, 2, 5, 8, 8, 9, 8, 8, 5, 3, 3, 2, 3, 3, 3, 2, 4, 4, 4, 4, 5,
0, 0, 0, 2, 6, 5, 3, 6, 9, 9, 8, 6, 6, 5, 4, 5, 2, 2, 3, 3, 4, 5, 5,
0, 0, 0, 0, 4, 3, 1, 3, 6, 8, 9, 9, 8, 6, 8, 6, 2, 2, 3, 3, 4, 5, 5,
0, 0, 0, 0, 5, 2, 0, 1, 4, 9, 9, 9, 9, 8, 8, 2, 1, 0, 2, 3, 4, 5, 5,
0, 0, 0, 0, 3, 4, 2, 6, 9, 9, 10, 9, 9, 7, 4, 0, 0, 0, 4, 4, 4, 5, 6,
0, 0, 0, 0, 3, 6, 7, 9, 9, 9, 9, 8, 3, 0, 0, 0, 0, 1, 8, 7, 4, 5, 6,
0, 0, 0, 0, 3, 6, 9, 9, 9, 9, 9, 3, 0, 0, 0, 0, 1, 7, 10, 10, 6, 5, 6,
0, 0, 0, 0, 5, 8, 9, 9, 9, 9, 5, 1, 0, 0, 0, 2, 7, 10, 10, 10, 10, 8, 7,
0, 0, 0, 0, 7, 9, 9, 9, 9, 8, 3, 1, 0, 3, 7, 9, 10, 10, 10, 11, 11, 11, 9,
0, 0, 0, 1, 7, 9, 9, 9, 6, 3, 1, 4, 8, 10, 10, 10, 10, 10, 11, 11, 11, 11, 11,
0, 0, 0, 1, 7, 8, 9, 9, 5, 4, 6, 10, 10, 10, 10, 10, 11, 11, 11, 11, 11, 11,
11,
0, 0, 0, 0, 3, 6, 9, 8, 7, 9, 9, 7, 8, 10, 11, 11, 11, 11, 11, 11, 11, 11, 11,
0, 0, 0, 0, 3, 9, 9, 1, 8, 9, 2, 3, 10, 10, 11, 11, 11, 11, 11, 11, 11, 11, 11
// Stepper motor objects: A is left, B is right
Stepper StepperA(motorStepsA, motorPinA1,motorPinA2);
Stepper StepperB(motorStepsB, motorPinB1,motorPinB2);
// Set up stepper motors and random # seed, if needed
delay(2000);
StepperA.setSpeed(15);
StepperB.setSpeed(15);
delay(2000);
randomSeed(analogRead(0));
float rads(int n) {
// Return an angle in radians
return (n/180.0 * PI);
void moveTo(int x2, int y2) {
// Turn the stepper motors to move the marker from the current point (x1,
// y1) to (x2, y2)
// Note: This only moves in a perfectly straight line if
// the distance is the same in both dimensions; this should be fixed, but it
// works well
// a2 and b2 are the final lengths of the left and right strings
int a2 = sqrt(pow(x2,2)+pow(y2,2));
int b2 = sqrt(pow((w-x2),2)+pow(y2,2));
int stepA;
int stepB;
if (a2>a1) {
stepA=1;
if (a1>a2) {
stepA=-1;
if (a2==a1) {
stepA=0;
if (b2>b1) {
stepB=1;
if (b1>b2) {
stepB=-1;
if (b2==b1) {
stepB=0;
// Change the length of a1 and b1 until they are equal to the desired length
while ((a1!=a2) || (b1!=b2)) {
if (a1!=a2) {
a1 += stepA;
StepperA.step(stepA);
if (b1!=b2) {
b1 += stepB;
StepperB.step(-stepB);
x1 = x2;
y1=y2;
void drawCurve(float x, float y, float fx, float fy, float cx, float cy) {
// Draw a Quadratic Bezier curve from (x, y) to (fx, fy) using control pt
// (cx, cy)
float xt=0;
float yt=0;
for (float t=0; t<=1; t+=.0025) {
xt = pow((1-t),2) *x + 2*t*(1-t)*cx+ pow(t,2)*fx;
yt = pow((1-t),2) *y + 2*t*(1-t)*cy+ pow(t,2)*fy;
moveTo(xt, yt);
void drawCircle(int centerx, int centery, int radius) {
// Estimate a circle using 20 arc Bezier curve segments
int segments =20;
int angle1 = 0;
int midpoint=0;
moveTo(centerx+radius, centery);
for (float angle2=360/segments; angle2<=360; angle2+=360/segments) {
midpoint = angle1+(angle2-angle1)/2;
float startx=centerx+radius*cos(rads(angle1));
float starty=centery+radius*sin(rads(angle1));
float endx=centerx+radius*cos(rads(angle2));
float endy=centery+radius*sin(rads(angle2));
int t1 = rads(angle1)*1000 ;
int t2 = rads(angle2)*1000;
int t3 = angle1;
int t4 = angle2;
drawCurve(startx,starty,endx,endy,
centerx+2*(radius*cos(rads(midpoint))-.25*(radius*cos(rads(angle1)))-.25*(radius*cos(rads(angle2)))),
centery+2*(radius*sin(rads(midpoint))-.25*(radius*sin(rads(angle1)))-.25*(radius*sin(rads(angle2))))
angle1=angle2;
void drawCircles(int number, int centerx, int centery, int r) {
// Draw a certain number of concentric circles at the given center with
// radius r
int dr=0;
if (number > 0) {
dr = r/number;
for (int k=0; k<number; k++) {
drawCircle(centerx, centery, r);
r=r-dr;
// Start in the lower right-hand corner, move left and up
for (int i=rows-1; i>=0; i--) {
for (int j=columns-1; j>=0; j--) {
char n = image[i*columns + j];
n = constrain(n, 0, 11);
// Draw big circles
drawCircles(n,
page0X+(j*cellW),
page0Y+(i*cellH),
radius);
if ((j>0) && (i>0)) {
// Draw little circles in-between big circles
// Average the values of the adjoining pixels
n=(image[(i-1)*columns + j]+
image[(i-1)*columns+j-1]+
image[i*columns+j-1]+
image[i*columns + j])/8;
drawCircles(n,
page0X+(j*cellW-(cellW/2)),
page0Y+(i*cellH-(cellH/2)),
radius/2);
// Move off page and wait
moveTo(page0X-500, y1);
while (1) {}
But as this code was made for uses with two different stepper motors to the ones I have, and was wondering if someone could help show me how to adjust the code to work with my steppers.
All I can really say is I believe my stepper motor steps at 7.5 degrease as when i run this code:
