I have a simple ISR to record the value of micros() everytime a QRE1113 reflective optical sensor detects the white blob on a disc on the shaft of a small motor.
The code in loop() figures out the time interval between pulses.
Most of the time this works fine but occasionally (perhaps 1 in 20) a very short interval is logged - usually less than half the correct interval. The correct intervals can range between about 100,000 µsecs and 4,000 µsecs depending on the motor speed.
I'm just wondering if anyone has a clever (i.e. simple and few CPU cycles) method to identify and ignore those incorrect intervals. A moving average would not be appropriate because that would give credence to the incorrect values.
Calculating the time difference in the ISR should consume too much time, so it might be an option. Just ensure all variables used in the ISR and the loop() code are declared volatile.
Delta_G:
Yes, @Robin should have posted all complete code. Or at least a minimal example that compiles and exhibits the issue. Of all people I would expect @Robin to know this.
I don't expect anyone to set up a similar experiment to see if they get the same problem. I believe I have stated the case with sufficient clarity. Maybe another way to present it is like this
8123
7990
7957
8011
3876
8001
7997
What is a clever way to detect and ignore the 3876?
pylon:
I have tried that. It does not make any difference. The problem seems to be that something spurious triggers the interrupt. And I have spent too much time trying to figure out the cause.
I don't think so. It's definitely better to find that error than to simply throw away value you don't like.
If you want to go that way, how about throwing all values away that aren't inside a +/-20% range of the previous value? You have to decide if that fits your setup.
Similar to the manner in which PWM duty cycles are derived and assuming you have a spare timer, when servicing your ISR, you know roughly when the next interrupt will arrive, say X microseconds. You also have some idea as to the rate of change that may occur, call it dX. The next interrupt then, is unlikely to occur before X - dX.
After setting newIsrMicros, set the OCR value on the available timer to OCR + (X - dX) and then turn your ISR off. The only instruction in the timerX_COMP_vect will then be to turn your ISR back on.
I'm wondering what the purpose of "newIsrMicros" is? If it is used to tell the "loop()" that there is new data to process, that data should be protected in the ISR by the same variable.
if (newIsrMicros)
//Do something with isrMicros
newIsrMicros = false; //Done playing with isrMicros
void revDetectorISR() {
if (newIsrMicros) return; //loop() has not handled isrMicros yet
isrMicros = micros();
newIsrMicros = true;
But for this to work properly, you would probably need to add a counter which counts how many times "revDetectISR" has been invoked without updating "isrMicros" and this would make the ISR a bit more bulky.
Ugh. I am just so tired of answering questions that are trivial to answer with Google. @Danois90, do some research. Nick Gammon's website is a great place to start.
OP's ISR is text book, timestamp, set flag, get out. Test the flag and deal with it elsewhere. The flag is only set in the ISR and only cleared by whatever function processes it.
DKWatson:
The ISR does not respect the flag it sets, that ain't "text book" coding to me since the timestamp and flag may be changed during "processing elsewhere".
Don't know where you learned your coding but the function of an ISR is to acknowledge an event and get out, full stop. By disrupting global interrupts any longer than that you negatively impact the deterministic behaviour of a bare metal, real-time processor.
DKWatson:
The interrupt handler for timer0 overflow is just nothing like that, yet it works splendid
FYI @Danois90, Arduino is a development/hobby platform. In the real world, a.k.a. commercial systems, we don't have functions like setup and loop and millis or any other 'behind-the-scenes' libraries that detract from the purpose of the processor. All of the 'nice to have' features that make Arduino such an attractive learning experience are not relevant in a bare-metal production system. As stated, the OP's ISR is exactly as it should be. 0210 here, Goodnight.
