Any code not works for me
Motor: Rocket F540 V2 4370KV
ESC: Readytosky Waterproof 60A(https://www.aliexpress.com/item/Readytosky-Waterproof-60A-Brushless-ESC-Electric-Speed-Controller-with-5-5V-3A-BEC-for-1-10/32864211143.html)
#include <Servo.h>
#define MAX_SIGNAL 2000
#define MIN_SIGNAL 700
#define MOTOR_PIN 9
int value = 0;
Servo motor;
  Serial.println("START");
  Serial.println("ESC is calibrating");
  motor.attach(MOTOR_PIN);
  motor.writeMicroseconds(MAX_SIGNAL);
  while (!Serial.available());
  Serial.read();
  motor.writeMicroseconds(MIN_SIGNAL);
  Serial.println("ESC calibrated");
  Serial.println("Speed: ");
    value = Serial.read();
    motor.writeMicroseconds(value);
and motor does not move
Look at one of the examples that come with the library.
You are reading from the serial input buffer even if there is no data available so most of the values returned are -1. To see how to read a number from Serial, reliably, see example #4 of the serial input basics tutorial. To change a number that is received as text to a number that can be used with servo.write, use the atoi() function.
#include <Servo.h>
#define MOTOR_PIN A0
int value = 0;
const byte numChars = 32;
char receivedChars[numChars];
boolean newData = false;
Servo motor;
    recvWithEndMarker();
    value = atoi(receivedChars);
    Serial.println(value);
void recvWithEndMarker() {
    static byte ndx = 0;
    char endMarker = '\n';
    char rc;
    if (Serial.available() > 0) {
        rc = Serial.read();
        if (rc != endMarker) {
            receivedChars[ndx] = rc;
            ndx++;
            if (ndx >= numChars) {
                ndx = numChars - 1;
        else {
            receivedChars[ndx] = '\0'; // terminate the string
            ndx = 0;
            newData = true;
still motor not started
Try this code and post the serial monitor output, please.
#include <Servo.h>
int value = 0;
Servo motor;
   if(newData == true)
   Serial.print("received characters  ");
   Serial.println(receivedChars);
   Serial.print("converted value  ");
   newData = false;
   char rc;
      rc = Serial.read();
         ndx++;
            ndx = numChars - 1;
         ndx = 0;
         newData = true;
Make sure that line endings is set to newline in serial monitor.
sth is maybe wrong or idk ... motor running after time ... 1 min or more and he stops after that ... and running again after seconds and stops again and not running anymore
unfortunately, nothing is happening right now :confused: yt
i want only left .. right and braking
Are you sure that you are performing a proper ESC arming sequence?
No now i'm not sure... I tested many code and anyone not works
1500 is minimum... 1600 = start
Do you have a manual for the ESC? I searched but can't find one.
Rekimo:
How is everything powered? That sounds like a bad battery or one that needs charging.
And your arming sequence looks more like a way of putting the ESC into programming mode,which is not what you want. What sounds do you hear from the ESC/motor?
Can you try it out using the Knob example program to see what values it really does respond to?
Steve
Only this:
Battery: zippy compact 2200mah 3s 25c lipo pack
Steve asked a few questions.
slipstick:
Steve
You replied with information about the battery, Steve's first question. The next 2 questions appear to have been ignored.
What sounds do you hear from the ESC/Motor?
Battery: 12.70V
Sounds: YT(yesterday was different .. like this beep beep and after calibration like this from YT)
YT: - YouTube
Knob: yeah .. when i buy some potentiometers(yep i don't have any...)
ok wait the minute ... not potentiometer .. but i have this
It looks like you are using a servo tester to feed the signal to the ESC and getting the motor to run. Good!
It also looks like you are printing some value to the serial monitor.
I do not know what value you are printing. It does not appear to have any correlation to what you are doing with the servo tester. How is the arduino involved with this experiment using the servo tester?
It would be interesting to have the arduino read the value that the servo tester is sending. Look in to how to read an EC receiver. If you were to print that value to the serial monitor and then use the servo tester to successfully arm and run the motor, then you could use those same values to do so from the arduino.
