Any GPS Arduino product available can record track/path?
Hi all,
I am very new in this field.
I would like to get some suggestions from you all about any Arduino products available in the market have GPS function with these specifications as below:
  1. can store track records.
  2. can function underground.
  3. Small in size.
  4. low battery consumption.
Appreciate if you can give some valuable suggestion on this.
Thank you.
Jeff
How far underground? GPS signal can get though a few mm of soil.
Maybe few meters. if the GPRS cannot detect then can it record the path it travel?
Is this for tracking mining vehicles or the progress of a drill head used for laying pipes?
If its the former then bluetooth or WiFi beacons placed in the tunnels can be used to gauge an approximate location.
actually, it is for running inside the pipe underground. So any device can do this?
JeffQ:
Laying a power cable and a beacon every 40 meters isn't going to be cheap. If the pipe is curved then you'll need more so there will always be line of sight to at least one beacon.
The cabling and the boxes to house the beacons will probably cost 100x more than the electronics inside.
I doubt this is a new idea. Perhaps see what the mining companies use for vehicle tracking and adapt that to your own needs.
Hi mikb55,
I do not think there will install power cable and beacons.
So there is no GPS Arduino that available for location detection for underground project? Or you have any other opinions?
Jeff
JeffQ:
GPSs do not work 'a few metres' (and is that 2m or 20m or more?) underground as has already been explained.
Try a google search on 'tracking animals underground' for some ideas as to how you could do it.
JeffQ:
Hi mikb55,
As srnet said, time to do some Google searches. try "underground navigation", then "Inertial navigation underground".
Hi mikb55 and srnet,
Thank you for the suggestion and information.
I will check the technology you said.
Thank you.
Jeff
