Any help/ideas on the project? Arduino UNO+Sim900 shield
I have created a alarm system which sends out sms if motion is detected. (For my boat). I can also control the system with sms commands. For example: Can turn off the PIR motion function. Can request temperature and humidity by sending 'temp' and 'hum' with sms.
I am not wize with the code.. please help if any comments. Any more ideas on this project or inprovements??
#include "SIM900.h"
#include "sms.h"
#include "SoftwareSerial.h"
#include "DHT.h"
#define DHTPIN A1     // DHT conected to this pin
#define DHTTYPE DHT22   // DHT 22  (AM2302)
SMSGSM sms;
DHT dht(DHTPIN, DHTTYPE);
boolean started=false;
long previousMillis = 0;
long interval = 120000;           // interval at which to blink (milliseconds)
char smsbuffer[10];
char n[18];
char string[30];
int val = 0;
int inputPin = A0;               // PIR sensor
int pirState = LOW;             // we start, assuming no motion detected
int pir = 10;
  //Serial connection.
  pinMode( 10, OUTPUT );
  digitalWrite( 10, HIGH );
  dht.begin();
  pinMode(inputPin, INPUT);
  Serial.println("GSM Shield testing.");
  if (gsm.begin(2400)){
    Serial.println("\nstatus=READY");
    started=true;
  else Serial.println("\nstatus=IDLE");
  if(started){
    delsms();
  float h = dht.readHumidity();
  float t = dht.readTemperature();
  int pos=0;
  int temp= (t);
  int temp1=(t*10)-(temp*10);
  int hum= (h);
  int hum1=(h*10)-(hum*10);
  sprintf(string,"Temp: %d.%dc | Hum: %d.%d", temp, temp1, hum, hum1 );
  if(started){
    pos=sms.IsSMSPresent(SMS_ALL);
    if(pos){
      Serial.println("Receiving SMS");
      Serial.println(pos);
      sms.GetSMS(pos,n,smsbuffer,10);
      Serial.println(n);
      Serial.println(smsbuffer);
      if(!strcmp(smsbuffer,"TEMP")){
        sms.SendSMS(n,string);
        Serial.println("\nSMS sent OK");
      if(!strcmp(smsbuffer,"PIRON")){
        digitalWrite(pir, HIGH);
        Serial.println("PIR on");
      if(!strcmp(smsbuffer,"PIROFF")){
        digitalWrite(pir, LOW);
        Serial.println("PIR off");
      delsms();
  val = digitalRead(inputPin);
  if (val == HIGH) {
    delay(150);
    if(currentMillis - previousMillis > interval) {
      if (pirState == LOW) {
        Serial.println("Motion detected!");
        pirState = HIGH;
        if(started){
          if (sms.SendSMS("+47xxxxxxxx", "Motion detected!"))
  else {
    delay(300);
    if (pirState == HIGH){
      Serial.println("Motion ended!");
      pirState = LOW;
void delsms(){
  Serial.println("Checking SIM card for messages...");
  for (int i=0; i<10; i++){
    int pos=sms.IsSMSPresent(SMS_ALL);
    if (pos!=0){
      Serial.print("\nFound SMS at the position ");
      if (sms.DeleteSMS(pos)==1){
        Serial.print("\nDeleted SMS at the position ");
        Serial.print("\nCant delete SMS at the position ");
It is very difficult to go through your code the way it is, use the auto format tool in the IDE or just press "Ctrl+T". Another thing is why are you putting semicolons on the closing brackets at the end of setup() and loop() " }; " ?
