any help would be great with this project.
hi people, i am currently copying this project and currently following it to a T.
i am having some problems and believe it could be with the code. was wondering if someone wouldnt mind taking a look and feeding back some input if possible.
i have broken the sections to make it easier to navigate.
http://practicalusage.com/?p=121 (part 1)
Line 6 Pedal Board: USB interface, with Arduino - Practical UsagePractical Usage (part 2)
Line 6 pedal board: Programming the Switches and LEDs - Practical UsagePractical Usage (part 3)
Line 6 pedal board: Programming the expression pedals - Practical UsagePractical Usage (part 4)
Line 6 pedal board: Re-using the main board - Practical UsagePractical Usage (part 5)
Line 6: Renaming it PU-1. - Practical UsagePractical Usage (part 6)
PU-1: Complete V 1.0 - Practical UsagePractical Usage (part 7)
each section is small just stupid its broken over a few sections.
like i said any help would deficatey be of a help.
thanks
marc
marcjwebb:
What problems? Post your code?
Read this before posting a programming question
 * First Section: configure the periodical execution of a user
 * defined function (Interrupt service routine) using Timer2. This
 * example will run the function every 1ms.
#include <Bounce.h>
/* Timer2 reload value, globally available */
unsigned int tcnt2;
int pin1 = 12;
int pin2 = 11;
int counter = 0;
int oldCounter = 0;
// Instantiate a Bounce object with a 5 millisecond debounce time
// Only pin1 needs to be debounced. It is assumed that pin2
// will be stable when reading pin1
Bounce bouncer1 = Bounce( pin1,5 );
/* Second Section:
Use 3 74HC595 shift registers to display 3 numbers on
common cathode 7-segments LEDs, and one more 595 to turn a series of
10 LEDs on and off.
This code should work for any digit assembly, but was specifically
used to recuperate the digits of an old Line 6 floor board.
U1 pin 12 is Latch
U1 pin 11 is Clock
U1 pin 14 is Serial data input.
int LatchPin = 6;
int ClockPin = 5;
int DataPin = 7;
char m[4];
byte data;
byte dataArray[10]; //character segment matrice
int k = 100; //divider for number display
int showLed = 0x00; //led array
int dp1 = 0x00; //connected to LED 1
int dp2 = 0x00; //connected to LED 2
int dp3 = 0x00; //connected to decimal point on digit 1
//definitions for pedals and their LEDs
int express=1;
int oldExpressValue = 0;
int wah=2;
int oldWahValue = 0;
int swresist=0;
int resistValue;
int showTemp = 0;
//third section: MIDI
// general midi notes
char note1 = 60; //Middle C
char note2 = 62; //D
char note3 = 64; //E
char note4 = 65; //F
char note5 = 67; //G
char note6 = 69; //A
char lastCmd[3] = {0x00,0x00,0x00};
//Fourth Section: General setup
int pin13 = 13;
  //setup for the display
  pinMode(LatchPin, OUTPUT);
  pinMode(ClockPin, OUTPUT);
  pinMode(DataPin, OUTPUT);
  //setup for the rotary encoder
  pinMode(pin1, INPUT);
  pinMode(pin2, INPUT);
  Serial.begin(31250);
//This section for the Timer Interrupt
   /* First disable the timer overflow interrupt while we're configuring */
  TIMSK2 &= ~(1<<TOIE2);
  /* Configure timer2 in normal mode (pure counting, no PWM etc.) */
  TCCR2A &= ~((1<<WGM21) | (1<<WGM20));
  TCCR2B &= ~(1<<WGM22);
  /* Select clock source: internal I/O clock */
  ASSR &= ~(1<<AS2);
  /* Disable Compare Match A interrupt enable (only want overflow) */
  TIMSK2 &= ~(1<<OCIE2A);
  /* Now configure the prescaler to CPU clock divided by 128 */
  TCCR2B |= (1<<CS22)  | (1<<CS20); // Set bits
  TCCR2B &= ~(1<<CS21);             // Clear bit
  /* We need to calculate a proper value to load the timer counter.
   * The following loads the value 131 into the Timer 2 counter register
   * The math behind this is:
   * (CPU frequency) / (prescaler value) = 125000 Hz = 8us.
   * (desired period) / 8us = 125.
   * MAX(uint8) + 1 - 125 = 131;
  /* Save value globally for later reload in ISR */
  tcnt2 = 131;
  /* Finally load end enable the timer */
  TCNT2 = tcnt2;
  TIMSK2 |= (1<<TOIE2);
 * Install the Interrupt Service Routine (ISR) for Timer2 overflow.
 * This is normally done by writing the address of the ISR in the
 * interrupt vector table but conveniently done by using ISR()  */
ISR(TIMER2_OVF_vect) {
  /* Reload the timer */
  TCNT2 = tcnt2;
  bouncer1.update();
  if(bouncer1.risingEdge()){
    oldCounter = counter;
    if (digitalRead(pin2)){
      counter--;
      else{
      counter++;
//End of Timer Interrupt section
//Define character images in an array
  dataArray[0] = 0x3f; // 0
  dataArray[1] = 0x06; // 1
  dataArray[2] = 0x5B; // 2
  dataArray[3] = 0x4F; // 3
  dataArray[4] = 0x66; // 4
  dataArray[5] = 0x6D; // 5
  dataArray[6] = 0x7C; // 6
  dataArray[7] = 0x07; // 7
  dataArray[8] = 0x7F; // 8
  dataArray[9] = 0x67; // 9
//Read pedal values and show reading from 0 - 127
//need to be calibrated by hand for now. Routine to come
int expressValue = map(analogRead(express),950,85,0,127);
if (expressValue < (oldExpressValue-1) || expressValue > (oldExpressValue+1)) {
  showValue(expressValue);
  oldExpressValue = expressValue;
  midiCmd(0xB0,0x0B, char(expressValue));
int wahValue = map(analogRead(wah),950,85,0,127);
if (wahValue < (oldWahValue-1) || wahValue > (oldWahValue+1)) {
  showValue(wahValue);
  oldWahValue = wahValue;
  midiCmd(0xB0,0x07,char(wahValue));
//treat resistor value. No switch pressed = 916/1024
//leds 10,8,7 as MSB then6,5,4 and 3 as LSB binaries
//into variable showLed
  resistValue = analogRead(swresist);
  if ((resistValue > 750) && (lastCmd[1] == char(0x90)) && (lastCmd[2] != 0x00)){ //no pedal pressed -> all notes off
    midiCmd(0x90,lastCmd[2],0x00);
    lastCmd[2] = 0x00;
//  Serial.println(resistValue);
  if (resistValue < 10){
     //Tuner ON
     showLed = 0x80;
     if(digitalRead(pin13) == LOW)
     digitalWrite(pin13,HIGH);
     digitalWrite(pin13,LOW);
  if (resistValue >= 35 & resistValue < 50){
    //Effect control OR Channel Select
    //Using LED 1 & 2
    delay(500); //wait for switch release. Might need interrupt
    if (dp1 == 0x00){
     dp1 = 0x80;
     dp2 = 0x00;
     dp3 = 0x00;
    }else {
     dp1 = 0x00;
     dp2 = 0x80;
     dp3 = 0x00;
     showLed = 0x00;
  if (resistValue >= 142 & resistValue < 155){
    if(lastCmd[2] != note1)
    midiCmd(0x90, note1, 0x45);
     showLed = 0x01;
  if (resistValue >= 205 & resistValue < 215){
    if(lastCmd[2] != note2)    midiCmd(0x90, note2, 0x45);
     showLed = 0x02;
  if (resistValue >= 270 & resistValue < 290){
    if(lastCmd[2] != note3)    midiCmd(0x90, note3, 0x45);
     showLed = 0x04;
  if (resistValue >= 350 & resistValue < 500){
    if(lastCmd[2] != note4)    midiCmd(0x90, note4, 0x45);
     showLed = 0x08;
  if (resistValue >= 575 & resistValue < 585){
    //Enter special mode. Light left Decimal point
     dp1 = 0x00;
     dp2 = 0x00;
     dp3 = 0x80;
  if (resistValue >= 640 & resistValue < 650){
    if(lastCmd[2] != note5)    midiCmd(0x90, note5, 0x45);
     showLed = 0x10;
  if (resistValue >= 710 & resistValue < 720){
    if(lastCmd[2] != note6)    midiCmd(0x90, note6, 0x45);
     showLed = 0x20;
//Getting ready to display values and indicators
  if (counter < 0 || counter > 999)
    counter = 0;
  if (oldCounter != counter){
    showValue(counter);
    midiCmdShort(0xC0,counter);
//Show me the number!
  liteUpDisplay();
  delay(5);
} /////END of LOOP
//Prepare array to cascade down shift registers
void showValue(int showNumber) {
  int k = 100;
  for (int i = 2; i >= 0; i--)
    m[i] = showNumber / k;
    showNumber = showNumber - (m[i] * k);
    k = k / 10;
//Display 3 digits and one of 3 indicators
void liteUpDisplay(){
  digitalWrite(LatchPin, LOW);
  //rightmost digit. Use | (or) with 0x80 to light led 2
  shiftOut(DataPin, ClockPin, MSBFIRST, dataArray[m[0]] | dp1);
  //middle digit. Use | (or) to light led 1
  shiftOut(DataPin, ClockPin, MSBFIRST, dataArray[m[1]] | dp2);
  //lefmost digit. Use | (or) to light decimal point
  shiftOut(DataPin, ClockPin, MSBFIRST, dataArray[m[2]] | dp3);
  //leds 10,8,7 then6,5,4 and 3 as MSB and LSB binaries
  shiftOut(DataPin, ClockPin, MSBFIRST, showLed);
  digitalWrite(LatchPin, HIGH);
// Send a MIDI Command with 3 parts
void midiCmd(char cmd, char data1, char data2) {
  lastCmd[1] = cmd;
  lastCmd[2] = data1;
  lastCmd[3] = data2;
  Serial.write(cmd);
  Serial.write(data1);
  Serial.write(data2);
// Send a MIDI Command with 2 parts
void midiCmdShort(char cmd, char data1) {
  lastCmd[1] = cmd;
  lastCmd[2] = data1;
  Serial.write(cmd);
Moderator edit: [code][/code] tags added. (Nick Gammon)
The code is supposed to be inside the code tags.
You haven't said what the problem is.
Sorry I'm still learning where everything is
My problem is that the switches do not do anything and neither do thief LEDs.
And also the led segment just flashes random displays
Cheers
Marc
