Any idea i got this error ArduinoIoTCloud.h no such file or directory
/usr/local/bin/arduino-cli compile --fqbn esp8266:esp8266:nodemcuv2:baud=115200,dbg=Disabled,eesz=4M,exception=disabled,ip=lm2f,lvl=None____,vt=flash,wipe=none,xtal=80 --build-cache-path /tmp --output-dir /tmp/1536099650/build --build-path /tmp/arduino-build-E8D723C5E32AD8470CEF16142AFC3285 --library /mnt/create-efs/webide/3e/e2/3ee21bab2b37558441fe1c806d430c22:se7en247/libraries_v2/GravityTDS /tmp/1536099650/TEST02_jul11a
In file included from /tmp/1536099650/TEST02_jul11a/TEST02_jul11a.ino:19:0:
/tmp/1536099650/TEST02_jul11a/thingProperties.h:2:29: fatal error: ArduinoIoTCloud.h: No such file or directory
#include <ArduinoIoTCloud.h>
compilation terminated.
Error during build: exit status 1
My code work well last night and when i try to test again i got this error any idea ? help me pls
  Sketch generated by the Arduino IoT Cloud Thing "Untitled 2"
  https://create.arduino.cc/cloud/things/66e66972-2413-4623-b19a-0b5cbb35b3d8
  Arduino IoT Cloud Variables description
  The following variables are automatically generated and updated when changes are made to the Thing
  String msg;
  CloudTemperatureSensor temperature;
  CloudRelativeHumidity humidity;
  Variables which are marked as READ/WRITE in the Cloud Thing will also have functions
  which are called when their values are changed from the Dashboard.
  These functions are generated with the Thing and added at the end of this sketch.
#include "thingProperties.h"
#include "DHT.h"
#define DHTpin 2 // D4 on the nodemcu ESP8266
#define DHTTYPE DHT11
DHT dht(DHTpin,DHTTYPE);
const int relayPin = 4;
  // Initialize serial and wait for port to open:
  // This delay gives the chance to wait for a Serial Monitor without blocking if none is found
  delay(3000);
  // Defined in thingProperties.h
  initProperties();
  // Connect to Arduino IoT Cloud
  ArduinoCloud.begin(ArduinoIoTPreferredConnection);
  pinMode(relayPin, OUTPUT);
     The following function allows you to obtain more information
     related to the state of network and IoT Cloud connection and errors
     the higher number the more granular information you’ll get.
     The default is 0 (only errors).
     Maximum is 4
  setDebugMessageLevel(2);
  ArduinoCloud.printDebugInfo();
  ArduinoCloud.update();
  // Your code here
 dht_sensor_getdata();
  Since Humidity is READ_WRITE variable, onHumidityChange() is
  executed every time a new value is received from IoT Cloud.
void onHumidityChange()  {
  // Add your code here to act upon Humidity change
  Since Msg is READ_WRITE variable, onMsgChange() is
void onMsgChange()  {
  // Add your code here to act upon Msg change
void dht_sensor_getdata()
    float hm= dht.readHumidity();
    Serial.print("Humidity ");Serial.println(hm);
    float temp=dht.readTemperature();
      Serial.print("Temperature ");Serial.println(temp);
  humidity=hm;
    temperature=temp;
    msg="Temperature = " + String (temperature)+"  Humidity = " + String(humidity);
   if (temp > 31.0) {
    // Activate the relay
    digitalWrite(relayPin, LOW);
    // Deactivate the relay
    digitalWrite(relayPin, HIGH);
Welcome to the forum
Start by posting your sketch, using code tags when you do
Sorry i am new for this forrum and my english is not that good
My last post i have an issue that ArduinoIoTCloud.h it like missing on Clound app then it happen to my all libaries on Arduino IoTCloud are gone i have to download manual such
ArduinoIotCloud.h
Arduino_ConnectioHandler
Arduino_DebugUtils
ArduinoMqttCilent
DHT_sensor
etc
pls help me if you have any idea what going on it this bug on clound or severdown ?
Hi @se7en247. Does the error still occur if you try again now? I just did some experiments and was not able to reproduce it.
This is quite unexpected because the ArduinoIoTCloud library is pre-installed in Arduino Cloud, so the header file ArduinoIoTCloud.h should always be available for use in your sketch code. This makes me think it might have been a transient fault and so might have been resolved since the time you experienced the error.
I have merged your cross-posts @se7en247.
Cross-posting is against the Arduino forum rules. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend a lot of time investigating and writing a detailed answer on one topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting can result in a suspension from the forum.
In the future, please only create one topic for each distinct subject matter. This is basic forum etiquette, as explained in the "How to get the best out of this forum" guide. It contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
It working now thank you very much for help me i think it bug form cloud software that make my account didnt reach libarries server
ในวันที่ พ. 19 ก.ค. 2023 04:47 น. ptillisch via Arduino Forum <notifications@arduino.discoursemail.com> เขียนว่า:
I'm glad it is working now. Thanks for taking the time to post an update!
Regards,
Per
Hi there,
I have the same error comming. It´s actually the same program I used some months ago and it worked perfectly fine. Now when trying to verify I get the error message: fatal error: ArduinoIoTCloud.h: No such file or directory
Any idea how to fix that?
Solved it by downloading libraries from GitHub and importing again. But that´s a strange behavior for the web editor, isn´t it?
I already slove this problem. It about Arduino cloud server it bug or lagging i think. I wait around 3-5 hour and comeback to run code on website everything trun to normal
ในวันที่ ศ. 15 ก.ย. 2023 20:47 น. Sip23 via Arduino Forum <notifications@arduino.discoursemail.com> เขียนว่า:
I have had same error now for 5 hours. I hope it it will compile normally again soon. Very annoying to be stopped working with a missing file in Arduino's file structure.
Hi all. I apologize for the problem. The Arduino Cloud developers have been notified of the problem. I'll report back here if I receive any news from them.
Hola parece que el problema persiste, me sale el mismo error, ayer compilaba un programa y ahora no, cabe mensionar que es el mismo programa el que ayer funcionaba y hoy sale el problema con la libreria iot cloud. aun no encuentro la solucion
I have an update:
The problem no longer occurs for me when compiling sketches using Arduino Web Editor.
So if you experienced the problem before while using Arduino Web Editor, please try again. Hopefully the error will no longer occur.
Unfortunately I do still experience the problem when compiling an Arduino IoT Cloud Thing sketch from the "Sketch" tab of Arduino IoT Cloud. So it seems the bug has not yet been fixed in Arduino IoT Cloud. However, I do have a workaround Arduino IoT Cloud users can use until it is fixed:
Please click the "Open full editor button you see in the "Sketch" tab of your Thing sketch. This will open the sketch in Arduino Web Editor. You can then compile or upload the sketch using Arduino Web Editor and the error should no longer occur.
Please let me know if you still have any questions or problems while using Arduino Cloud.
The remaining bug that caused the unexpected "No such file or directory" errors when compiling from the "Sketch" tab of Arduino IoT Cloud should now be fixed. So it is no longer necessary to use the workaround I described earlier of using the "full editor" to compile and upload.
