Any ideas? On what i should do?
Well, I’ve got 2 low power relays(can be turned on or off with the arduino), 2 phototransistors, Some LED’s, Some 20K resistors, Some 200 ohm resistors, and a laser.
Any ideas?
laser tripwire for lighting?
Hmmm…I would need a higher power relay for the lighting part…
I would still go with something about laser trip wire. Got a piezo buzzer or speaker laying around? :slight_smile:
Got a buzzer…Hmmm…But I don’t have any cable…At least any more than 2 ft
bump
laser tripwire that has a sexy voice saying hello when you walk in
and what? no wire?
go to the home improvement store, they sell it in all flavors fairly cheap
Another lazer tripwire? I can’t do that. >_< I don’t have enough cable.
ok ok fine no wire …
try beaming a serial signal across the room using the laser
What do you mean beaming a signal?
hook up the laser to an output and see if you can ReCreate* the signal on the other side using your phototransistors
*eh eh! bad pun on your name, ++props :-?
I assume Osgeld is referring to a morse-code type of communication that sends messages by flashing on/off the laser and receiving it on the diode. I’m pretty sure I’ve seen someone (Make Magazine, perhaps?) doing this just by hooking up the laser to the TX pin, and then hooking the photodiode to the RX pin, and using serialPrint() and serialRead().
course you could just do a laser tripwire by putting batteries on the laser and the arduino as the receiver
::slight_smile:
:o
(runs away quickly!)
Hmmm…Like a data transfer link? Hmmm…
Check this:
http://www.ohmpie.com/laserModem
There appears to be a problem. On the RX pin when no data is being sent it is at about 3V(judging by the dim-ness of the LED) and when data is sent it goes even lower to, i guess, 1V. Is this right?
have a meter?
(and I dont know i havent messed with the serial pins yet)
Not really…I know someone who does though. But the cable is messed up…
well the holidays are apon us, and they can be had pretty cheaply (I saw a pretty decent model @ k-mart for like 12 bucks)
These are one of the few “MUST HAVE” tools when fiddling with electronics (along with some wire nippers)
Well yeah, But I’d be nice if i could get this working before Christmas. :wink:
