any ideas?
hi there i have written this sketch which seems to work how i want it to apart from one thing where i have written at this point where it should bring on the lock out LED it doesnt seem to any ideas?
const int heatbutton = 2;
const int ventbutton = 3;
const int ignition = 4;
const int saleswitch = 5;
const int solenoid = 6;
const int photo_pressure = 7;
const int lockoutled = 13;
const int resetbutton = 9;
const int fan = 10;
const int map1_or2 = 11;
  pinMode(heatbutton, INPUT);
  pinMode(ventbutton, INPUT);
  pinMode(ignition, OUTPUT);
  pinMode(saleswitch, INPUT);
  pinMode(photo_pressure, INPUT);
  pinMode(lockoutled, OUTPUT);
  pinMode(resetbutton, OUTPUT);
  pinMode(fan, OUTPUT);
  pinMode(map1_or2, INPUT);
  void loop(){
  if (digitalRead(ventbutton)==HIGH) {                       // vent button
        digitalWrite(fan, HIGH); }
        else {
          digitalWrite(fan, LOW); }
if (digitalRead(heatbutton)==LOW) {
  if (digitalRead(photo_pressure)==LOW) {                  //    low gas pressure
   digitalWrite(lockoutled, HIGH);                         // when heat button is LOW
   digitalWrite(solenoid, LOW); }
  while (digitalRead(resetbutton)==HIGH) {
  digitalWrite(lockoutled, LOW);
  return; } }
  if (digitalRead(heatbutton)==HIGH) {                    // Heat button
  delay(2500);
  if (digitalRead(saleswitch)==HIGH) {                  // sale switch if HIGH
  digitalWrite(solenoid, HIGH); }
  else {                                                // sale switch if LOW
   digitalWrite(lockoutled, HIGH);     //at this point
  while (digitalRead(resetbutton)!=HIGH) {
  digitalWrite(lockoutled, LOW); }
  return; }
      delay(3000);
    if (digitalRead(photo_pressure)==LOW) {            // pressure if LOW
   digitalWrite(lockoutled, HIGH);     // at this point
   digitalWrite(lockoutled, LOW); } }
      else {                                          // switching off
Maybe you should explain the prupose of the sketch, what you expect for output and what you got ?
Maybe you should put each { and } on it's own line, and use the Tools + Auto format option to make the code readable.
Actually, there's no maybe about it.
when i have written //at this point it sould make the lockoutled HIGH but it does now tho?
A // is a comment; it can't make anything execute.
sorry when i say //at this point i was referring to that line on the sketch i posted
There are several comments in the code you posted. Please, format the code. My eyes hurt looking at it.
else {
  return; }
and the other
any ideas?
try reading the replies already made then follow the advice
Try putting a delay(2000); after this: digitalWrite(lockoutled, HIGH);
Should prove enlightening.
hi i have put the delay in and that works but only for the time of the delay what is no good and i have played with this { and } could not get it any beter
What if resetbutton was changed to pinMode INPUT?
sorry could you give me an example thanks
OK. Not like this: pinMode(resetbutton, OUTPUT);
EDIT: Sorry, tags got tangled.
Not like this: code]pinMode(resetbutton, OUTPUT);
what is that meant to mean??
i put it in the loop and now the fan does not turn off aswell as the original problem
Sorry, my tags got tangled.
I assumed that if you were reading "resetbutton", you'd want to make it an input, not an output.
o ok
still not working now it flashes between the fan and the lockoutled
this is seding me around the bend now lol
const int fan            = 10;
  pinMode(resetbutton,    INPUT);             // Added by jameshappy
  pinMode(solenoid,       OUTPUT);            // Added by jameshappy
  //pinMode(resetbutton,  OUTPUT);            // Commented by jameshappy
void loop(){
  if (digitalRead(ventbutton) == HIGH) {      // vent button
  else {
  if (digitalRead(heatbutton) == LOW) {
    if (digitalRead(photo_pressure) == LOW) { // low gas pressure
    while (digitalRead(resetbutton) == HIGH) {
      return;
  if (digitalRead(heatbutton) == HIGH) {      // Heat button
    delay(2500);
    if (digitalRead(saleswitch) == HIGH) {    // sale switch if HIGH
      // Turn on lockoutled
      // Turn off solenoid
      // Turn off fan
      // Turn off lockoutled while the resetbutton is not being pressed
      while (digitalRead(resetbutton) != HIGH) {
      return;
    delay(3000);
    if (digitalRead(photo_pressure) == LOW) { // pressure if LOW
      // Turn off fan
I think this is what you need:
// Turn off fan
// Wait for opperator to clear fault
  delayMicroseconds(1); // Optional
