Is there any option that we can change the pitch of an audio file in real time ??
I mean
Can we make changes in the operation of DF Player with the help of code to get the a varied or desired Pitch or frequency of an audio file ?
If not then,
Is there any option to convert the pitch of sound obtained externally from the line out of the DF Player or any Player in real time with help of an MCU like an arduino or any other ready made board ??
I am not using it for any audio functioning , just I have
OK hv to check !!
Sir is there any command to switch between USB and SD Card option for DF PLayer ??
I am not finding the right one actually !!
Just blah blah things and explanations are there but not the required perfect one !!
I use to operate with pause/play action with help of this configuration but sometimes pause button starts acting for next audio file button and switching songs one by one at every press
And some times work normally
Is there any connection or wiring or hardware issue ?
The DFplayer mini has a USB port that can operate as a Host (to read files from a USB stick) or can also operate as a device, so that the PC can access the files from the SD card (and there is also a possibility to use the DFplayer Mini as sound card, but I believe the "clones" do not have this support)
