Any reason why I wouldn't be able to connect to IoT Cloud?
I have a MKR1000, up to date firmware as far as I can tell, I did the potentiometer part of the Getting Started tutorial, adding a line to output to the serial monitor, so I know that works, but get nothing on my dashboard.
My serial bus output is as follows, with … inserted where there is repetition of the time, analogue pin, and so on…
381
390
387
::CONNECTING
WiFi.status(): 3
Connected to "MyWiFi"
309
381
347
NetworkConnectionState::GETTIME
Arduino IoT Cloud Connection status: CONNECTING
343
NTP time: 1573819829
ArduinoCloud.connect(): 0
311
NTP time: 1573819830
299
NTP time: 1573819848
303
WiFi.status(): 3
NTP time: 1573819850
297
NTP time: 1573819869
311
WiFi.status(): 3
And this continues. I can upload sketches to the board fine, and the monitor shows the value at the analogue pin changing, but it’s not connecting to the Arduino IoT Cloud. Any advice on what to check or even hints on how to debug this further?
My .ino :
#include "thingProperties.h"
  // Initialize serial and wait for port to open:
  // This delay gives the chance to wait for a Serial Monitor without blocking if none is found
  delay(1500);
  // Defined in thingProperties.h
  initProperties();
  // Connect to Arduino IoT Cloud
  ArduinoCloud.begin(ArduinoIoTPreferredConnection);
     The following function allows you to obtain more information
     related to the state of network and IoT Cloud connection and errors
     the higher number the more granular information you’ll get.
     The default is 0 (only errors).
     Maximum is 4
  setDebugMessageLevel(4);
  ArduinoCloud.printDebugInfo();
  ArduinoCloud.update();
  angle1 = analogRead(A0);
  Serial.println(angle1);
and thingProperties.h :
#include <ArduinoIoTCloud.h>
#include <Arduino_ConnectionHandler.h>
const char THING_ID[] = "fd895cd9-9496-41aa-9365-e983ebc4d2ed";
const char SSID[]     = SECRET_SSID;    // Network SSID (name)
const char PASS[]     = SECRET_PASS;    // Network password (use for WPA, or use as key for WEP)
int angle1;
void initProperties(){
  ArduinoCloud.setThingId(THING_ID);
  ArduinoCloud.addProperty(angle1, READ, 1 * SECONDS, NULL);
WiFiConnectionHandler ArduinoIoTPreferredConnection(SSID, PASS);
hi
can you try and add a delay(5000) before ArduinoCloud.printDebugInfo(); ?
also... did you go through the Arduino IoT Cloud Getting Started guide to provision your board?
try going through it again just to be sure, then select the board in your Thing's board tab.
https://create.arduino.cc/getting-started
Hiya,
Yep, that did the trick, many thanks! I feel like I did do Getting Started the first time, but maybe something went wrong and I didn’t realise ::slight_smile:
Onwards!!
