system
February 17, 2014, 12:12pm
1
Hi:
I have a robot which can be controlled by PC via usb cable, and I wanna make it become wireless.
So I try to use Yun to make a Wireless USB port/hub, but I don't know how to do it.
I checked the example on the arduino website but I didn't find something about communication between TCP/IP and USB port.
Then I wanna find a tool which can be installed on linino to make USB port can be shared by network. I found "usbip" may be useful but it could not be installed by "opkg install" now.
Could someone help me?
Thanks
Matthew
lucad79
February 17, 2014, 12:45pm
2
Hi Mattew,
I can't try now because I'm at work but this guide may help you:
http://wiki.openwrt.org/doc/howto/usb.iptunnel
I think the required packages are included in the Linino repository too...
let me know if it works!
system
February 17, 2014, 2:20pm
3
Hi lucadentella:
I have read this website. I think it is a instruction about usbip.
Then, I tried to use usbip on my laptops with ubuntu 13.04 to share a usb but failed.
root@Matthewslaptop:~# usbip_bind_driver --usbip 1-1
** (process:1306): WARNING **: add 1-1 to match_busid, failed
I tried to find a solution by google and it seems that the software is too old to run with the new linux kernel.
And if it can works on linux. I still can't compile this code on Yun because there is no a C compiler on Yun. Maybe I can try cross compiling for Yun.
Thank you
Matthew
sonnyyu
February 18, 2014, 2:54pm
4
The usbip at userspace in linino is missing, only kernel one exist. The up stream OS (Openwrt) is broken.
New Yun image has those:
kmod-usbip - 3.3.8-1 - USB-over-IP kernel support
kmod-usbip-client - 3.3.8-1 - USB-over-IP client driver
kmod-usbip-server - 3.3.8-1 - USB-over-IP host driver
usbip - 1.1.1-2 - USB-over-IP (common)
usbip-client - 1.1.1-2 - USB-over-IP (client)
usbip-server - 1.1.1-2 - USB-over-IP (server)
I am not sure it get fixed.
Checkout Vadorequest's project: GitHub - Vadorequest/AAD1: Car controlled by Wifi, using an Android application It's about using a yun to control a car via wifi
Since kernel 2.6.28 usbip is in the kernel mainline, the problem is in up stream OS.
