Hello guys I am working on a project, which is 4 relays with 1 fan speed control(live feedback also)
I want to add one more condition in my project, related to fan speed control,
first is one more button for a fan on/off and one regulator switch for manually control of fan speed can someone help me,
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#include <RBDdimmer.h>
BlynkTimer timer;
#define DEBUG_SW 0
#define S1 34
#define R1 18
#define S2 35
#define R2 19
#define S3 36
#define R3 21
#define S4 39
#define R4 22
#define outputPin 27
#define zerocross 25
dimmerLamp dimmer(outputPin, zerocross);
int MODE = 0;
int outVal = 0;
int dim_val;
char ssid[] = "Yogendra";
char pass[] = "Jamsariya";
char auth[] = "......................."; //blynk app auth
int switch_ON_Flag1_previous_I = 0;
int switch_ON_Flag2_previous_I = 0;
int switch_ON_Flag3_previous_I = 0;
int switch_ON_Flag4_previous_I = 0;
BLYNK_WRITE(V0) {
outVal = param.asInt();
dim_val = map(outVal, 0, 1023, 0, 100);
dimmer.setPower(dim_val);
//Blynk.virtualWrite(V1, dim_val);
BLYNK_WRITE(V1)
int pinValue = param.asInt();
digitalWrite(R1, pinValue);
BLYNK_WRITE(V2)
digitalWrite(R2, pinValue);
BLYNK_WRITE(V3)
digitalWrite(R3, pinValue);
BLYNK_WRITE(V4)
digitalWrite(R4, pinValue);
void with_internet()
if (digitalRead(S1) == LOW)
if (switch_ON_Flag1_previous_I == 0 )
digitalWrite(R1, LOW);
if (DEBUG_SW) Serial.println("Relay1- ON");
Blynk.virtualWrite(V1, 0);
switch_ON_Flag1_previous_I = 1;
if (DEBUG_SW) Serial.println("Switch1 -ON");
if (digitalRead(S1) == HIGH )
if (switch_ON_Flag1_previous_I == 1)
digitalWrite(R1, HIGH);
if (DEBUG_SW) Serial.println("Relay1 OFF");
Blynk.virtualWrite(V1, 1);
if (DEBUG_SW)Serial.println("Switch1 OFF");
if (digitalRead(S2) == LOW)
if (switch_ON_Flag2_previous_I == 0 )
digitalWrite(R2, LOW);
if (DEBUG_SW) Serial.println("Relay2- ON");
Blynk.virtualWrite(V2, 0);
switch_ON_Flag2_previous_I = 1;
if (DEBUG_SW) Serial.println("Switch2 -ON");
if (digitalRead(S2) == HIGH )
if (switch_ON_Flag2_previous_I == 1)
digitalWrite(R2, HIGH);
if (DEBUG_SW) Serial.println("Relay2 OFF");
Blynk.virtualWrite(V2, 1);
if (DEBUG_SW)Serial.println("Switch2 OFF");
//delay(200);
if (digitalRead(S3) == LOW)
if (switch_ON_Flag3_previous_I == 0 )
digitalWrite(R3, LOW);
if (DEBUG_SW) Serial.println("Relay3- ON");
Blynk.virtualWrite(V3, 0);
switch_ON_Flag3_previous_I = 1;
if (DEBUG_SW) Serial.println("Switch3 -ON");
if (digitalRead(S3) == HIGH )
if (switch_ON_Flag3_previous_I == 1)
digitalWrite(R3, HIGH);
if (DEBUG_SW) Serial.println("Relay3 OFF");
Blynk.virtualWrite(V3, 1);
if (DEBUG_SW)Serial.println("Switch3 OFF");
//delay(200);
if (digitalRead(S4) == LOW)
if (switch_ON_Flag4_previous_I == 0 )
digitalWrite(R4, LOW);
if (DEBUG_SW) Serial.println("Relay4- ON");
Blynk.virtualWrite(V4, 0);
switch_ON_Flag4_previous_I = 1;
if (DEBUG_SW) Serial.println("Switch4 -ON");
if (digitalRead(S4) == HIGH )
if (switch_ON_Flag4_previous_I == 1)
digitalWrite(R4, HIGH);
if (DEBUG_SW) Serial.println("Relay4 OFF");
Blynk.virtualWrite(V4, 1);
if (DEBUG_SW)Serial.println("Switch4 OFF");
//delay(200);
void without_internet()
digitalWrite(R1, digitalRead(S1));
digitalWrite(R2, digitalRead(S2));
digitalWrite(R3, digitalRead(S3));
digitalWrite(R4, digitalRead(S4));
void checkBlynk() { // called every 3 seconds by SimpleTimer
bool isconnected = Blynk.connected();
if (isconnected == false) {
MODE = 1;
if (isconnected == true) {
MODE = 0;
// Debug console
if (DEBUG_SW) Serial.begin(9600);
pinMode(S1, INPUT);
pinMode(R1, OUTPUT);
pinMode(S2, INPUT);
pinMode(R2, OUTPUT);
pinMode(S3, INPUT);
pinMode(R3, OUTPUT);
pinMode(S4, INPUT);
pinMode(R4, OUTPUT);
WiFi.begin(ssid, pass);
timer.setInterval(3000L, checkBlynk); // check if connected to Blynk server every 3 seconds
Blynk.config(auth);//, ssid, pass);
dimmer.begin(NORMAL_MODE, ON); //dimmer initialisation: name.begin(MODE, STATE)
if (WiFi.status() != WL_CONNECTED)
if (DEBUG_SW) Serial.println("Not Connected");
if (DEBUG_SW) Serial.println(" Connected");
Blynk.run();
timer.run(); // Initiates SimpleTimer
if (MODE == 0)
with_internet();
without_internet();
