http://www.pjrc.com/teensy/td_libs_Encoder.html
Doesn't seem to count any pulses on my side, works with the UNO tho.
By the way, the voltage output of the encoder is about 40 mV for a high when Vcc is connect to 5V, is that normal?
40mV is decidedly LOW. Do you have a pullup? Internal pullups are usually sufficient.
MorganS:
Hmmm that seemed to work after I added write high to my pins in setup. Odd since I didn't have to do that on the Uno
