Anyone know about interfacing thinger io with esp32 and lora?
Hi, previously I made a data transmission program from esp32 to another esp32 using LoRa, and using thinger io as the interface resulting from sending the sensor data.
Well before I tried to connect and send data to thinger io and it worked.
but now the data from esp32(receiver) not showing on thinger io.
and this is when i try again now
my code :
#include <LoRa.h>
#include <SPI.h>
#define ss 5
#define rst 14
#define dio0 2
#define THINGER_SERIAL_DEBUG
#include <ThingerESP32.h>
#include "arduino_secrets.h"
ThingerESP32 thing(USERNAME, DEVICE_ID, DEVICE_CREDENTIAL);
int rssi;
String LoRaMessage;
String jarak;
String sensorValue;
String sensorVoltage;
String tinggiAir;
String readingID;
// Replaces placeholder with Sensor values
String processor(const String& var){
  //Serial.println(var);
  if(var == "jarak"){
    return jarak;
  else if(var == "tinggiair"){
    return tinggiAir;
  else if(var == "sensorValue"){
    return sensorValue;
  else if (var == "RRSI"){
    return String(rssi);
  return String();
  // open serial for debugging
  thing.add_wifi(SSID, SSID_PASSWORD);
while (!Serial);
  Serial.println("LoRa Receiver");
 int counter;
  LoRa.setPins(ss, rst, dio0);    //setup LoRa transceiver module
  while (!LoRa.begin(433E6) && counter < 10)     //433E6 - Asia, 866E6 - Europe, 915E6 - North America
    Serial.println(".");
    counter++;
  LoRa.setSyncWord(0xA5);
  Serial.println("LoRa Initializing OK!");
  thing["SONIC"] >> [](pson& out){
  out ["jarak"] = jarak;
  thing["WaterLevel"] >> [](pson& out){
  out ["tinggiAir"] = tinggiAir;
  int packetSize = LoRa.parsePacket();    // try to parse packet
  if (packetSize)
    Serial.print("Received packet '");
    while (LoRa.available())              // read packet
      String LoRaData = LoRa.readString();
      Serial.print(LoRaData);
    int pos1 = LoRaData.indexOf('/');
    int pos2 = LoRaData.indexOf('&');
    readingID = LoRaData.substring(0, pos1);
    jarak = LoRaData.substring(pos1 +1, pos2);
    tinggiAir = LoRaData.substring(pos2+1, LoRaData.length());
    Serial.print("' with RSSI ");         // print RSSI of packet
    Serial.println(LoRa.packetRssi());
   thing.handle();
