It's 7mm wide and 6mm deep, connects to an arduino on an Ortur laser
I'm trying to source it but having no luck whatsoever
Pin spacing, in mm likely?
Hi - slightly over 1mm
Where about on an Arduino?
What model Arduino.
Do you need one, or just want to know what voltage/current it can transfer?
Thanks.. Tom...
Hi - I'm not very well up on the subject! A friend who is told me it's an arduino but not which type.
I'm just trying to find one as I need to make up a cable - it controls light and extraction
Thanks,
Richard
Okay, then get back to him and find out, the only six pin "connector" on a UNO or Nano is these pins but they are 0.1" spacing not 1mm.
Sounds like the connection is to a module PCB that connects to an Arduino.
If you need to extend the cable, then cut it and add more wire.
Use the existing plugs/sockets.
Thanks.. Tom...
That is 1.27 mm
0.05" pitch.
Thanks.. Tom...
According to this link it's a "PHB" type connector. Connector identification for Ortur 10W laser module laser-to-adapter-board cable - Electrical Engineering Stack Exchange
Everything thanks to this stupid imperial system. Or metric system. Depending on which side of the ocean you are. Of course.
That's exactly it - thanks so much
Just need to try and buy some now!
"it's not on Mouser"
I noticed!
Please take 2 seconds to mark @bobcousins answer the solution. Thank you ![]()
