anyone knows this wifi module ?
I've received this module (http://www.junetrading.com/catalog/product_info.php?products_id=5621), and have no idea - how to use it with an arduino (if that's possible at all..) :-[
anyone knows anything about this unit??
Presumably from links, it is the module used on this shield: http://www.cutedigi.com/forum/viewtopic.php?f=17&t=47&sid=5e5367bd476ef60bfb5473699fa43750
Connect up what's on the shield and use the WiShield example code and you should be good to go.
Mowcius
do you know if i could get some breakout board for this module ?
Not that I know of. I thought you might be able to buy the async labs wishield PCB seperately but no luck. Maybe if you contact them they might be willing to send you just the PCB or the PCB + the other components you are going to need.
Mowcius
