Anyone made their own Mega?
Hi there,
Was wondering if anyone has made there own arduino mega? I imagine its easer to make the 1280 version, any1 given it a bash?
You mean using the mega board files?
People have made a number of boards using the ATmega 1280 or 2560 chip (or just other ATmega SMD chips which have less pins).
I have not seen any boards produced 'at home' with the ATmega 1280 on but I have seen other SMD chips done on home-made circuit boards.
So... what exactly is the question? :wink:
Thanks for your response. Basically I want a board that I can get etched on a milling machine, which has the atmega1280 chip and which I can run in the arduino environment. Any eagle files in the public domain that I could use?
How accurate's your milling machine?
So basically you're looking for a single layer board. I don't think I've seen any...
It looks like you already asked this question:
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1287171388/9
yip I have, that forum started to get a bit off topic so I reposted to see If I would have more luck. Thanks for your help mate :slight_smile:
I can etch 2 layer myself but it takes so much time just to make 1 board and its not the cheapest, I used a mega clone board (yes made in china and cost about £3) then built with custom components e.g larger 2560 chip :slight_smile:
check my post out for images of the build:
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1288073504
