Anyone out there in YUN land using the Yun compatible Dragino MS14S?
I have one the Dragino MS14S (I paid $44.00 plus a few dollars shipping for it) and it does run any of the YUN bridge examples and any thing else written for the YUn . . It does not have a micro SD card connector but I have been able to use a thumb drive USB flash instead. It mounts as sda1 or what ever...http://store.linksprite.com/arduino-yun-compatible-io-gateway/ general info on the OpenWrt wiki : http://wiki.openwrt.org/toh/dragino/ms14 My question is about updating the OpenWRT . I tried the YUN update instructions and it did not work... I searched the OpenWrt Wiki forum and some think that the Dragino has a different Flash and RAM set up....it is currently running the Linino OpenWrt : built=Wed Dec 11 17:54:50 CST 2013
Any ideas???
David G.
http://www.dragino.com/
OEM web site.
http://www.dragino.com/downloads/index.php?dir=motherboards/ms14/Firmware/Yun/middleware.1/
The firmware download url.
Thanks for your research. I contacted Dragino and they directed me to the upgrade instructions :
: http://wiki.dragino.com/index.php?title=Getting_Start_with_Arduino_Yun#Upgrade_MS14_Firmware
the latest upgrade is located at : http://www.dragino.com/downloads/downloads/motherboards/ms14/Firmware/Yun/Beta1.3/
It is a painless process that does not require a micro sd card (the MS14 doesn't have one) it is all handled by the wifi connection, fast and easy; an automatic root boot after flashing and you are back up and running the application you had loaded before !!!
All and all I am impressed with the level of detail and support that Dargino offers in this nicely packed product.
David Garrison
sierrasmith71: I have one the Dragino MS14S (I paid $44.00 plus a few dollars shipping for it) and it does run any of the YUN bridge examples and any thing else written for the YUn . . It does not have a micro SD card connector but I have been able to use a thumb drive USB flash instead. It mounts as sda1 or what ever...http://store.linksprite.com/arduino-yun-compatible-io-gateway/ ...
Is this one coming with arduino daughterboard?
Yes, it has the Dragino M32 daughter board installed which has the same MCU that the Leonardo has.
David G.
