Please provide me solution using TLE7259 for LIN BUS using arduino nano
If you search the web with your argument:
"TLE7259 for LIN BUS using arduino"
will find the solution.
"Who seeks, finds"
If you do not fine then post an annotated schematic of your circuit showing all connections, power and ground. Also post your code.
My Master Code
#include <LIN_master.h>
// Define LIN ID for power window control
#define LIN_ID_POWER_WINDOW 0x15
// Define data values for power window control
#define POWER_WINDOW_UP_CMD 0x01
#define POWER_WINDOW_DOWN_CMD 0x02
// Define pin numbers for buttons
#define BUTTON_FR_LEFT_PIN 2
#define BUTTON_FR_RIGHT_PIN 3
#define BUTTON_RR_LEFT_PIN 4
#define BUTTON_RR_RIGHT_PIN 5
// Instantiate LIN_Master object
LIN_Master linMaster;
// Begin serial communication
// Initialize LIN communication
linMaster.begin(19200, LIN_V2, false); // Baudrate 19200, LIN version 2, no background operation
// Initialize button pins as inputs
pinMode(BUTTON_FR_LEFT_PIN, INPUT_PULLUP);
pinMode(BUTTON_FR_RIGHT_PIN, INPUT_PULLUP);
pinMode(BUTTON_RR_LEFT_PIN, INPUT_PULLUP);
pinMode(BUTTON_RR_RIGHT_PIN, INPUT_PULLUP);
// Read current state of buttons
bool currentButtonStateFrLeft = digitalRead(BUTTON_FR_LEFT_PIN);
bool currentButtonStateFrRight = digitalRead(BUTTON_FR_RIGHT_PIN);
bool currentButtonStateRrLeft = digitalRead(BUTTON_RR_LEFT_PIN);
bool currentButtonStateRrRight = digitalRead(BUTTON_RR_RIGHT_PIN);
// Check if button FR_LEFT is pressed (active high)
if (currentButtonStateFrLeft == HIGH) {
sendPowerWindowCommand(0x01, POWER_WINDOW_UP_CMD); // Start bit: 0x01
sendPowerWindowCommand(0x01, POWER_WINDOW_DOWN_CMD); // Start bit: 0x01
// Check if button FR_RIGHT is pressed (active high)
if (currentButtonStateFrRight == HIGH) {
sendPowerWindowCommand(0x02, POWER_WINDOW_UP_CMD); // Start bit: 0x02
sendPowerWindowCommand(0x02, POWER_WINDOW_DOWN_CMD); // Start bit: 0x02
// Check if button RR_LEFT is pressed (active high)
if (currentButtonStateRrLeft == HIGH) {
sendPowerWindowCommand(0x03, POWER_WINDOW_UP_CMD); // Start bit: 0x03
sendPowerWindowCommand(0x03, POWER_WINDOW_DOWN_CMD); // Start bit: 0x03
// Check if button RR_RIGHT is pressed (active high)
if (currentButtonStateRrRight == HIGH) {
sendPowerWindowCommand(0x04, POWER_WINDOW_UP_CMD); // Start bit: 0x04
sendPowerWindowCommand(0x04, POWER_WINDOW_DOWN_CMD); // Start bit: 0x04
// Delay to debounce buttons
delay(50);
// Receive response from slave
receivePowerWindowResponse();
// Function to send power window control command via LIN
void sendPowerWindowCommand(uint8_t startBit, uint8_t command) {
// Data to be sent
uint8_t data[] = {startBit, 0x01, command}; // Start bit, Data length, Command
// Send a master request frame with LIN header
linMaster.sendMasterRequest(LIN_ID_POWER_WINDOW, sizeof(data), data);
// Print the data being sent
Serial.print("Sent LIN frame: ");
for (int i = 0; i < sizeof(data); i++) {
Serial.print(data[i], HEX);
Serial.print(" ");
// Function to receive power window response from LIN slave
void receivePowerWindowResponse() {
// Buffer to store received data
uint8_t receivedData[8];
// Receive slave response frame
LIN_error_t error = linMaster.receiveSlaveResponse(LIN_ID_POWER_WINDOW, sizeof(receivedData), receivedData);
// Check for errors
if (error == LIN_SUCCESS) {
// Print received data
Serial.print("Received LIN response: ");
for (int i = 0; i < sizeof(receivedData); i++) {
Serial.print(receivedData[i], HEX);
Serial.print(" ");
// Print error message
Serial.println("Error receiving LIN response");
My Slave Code
#include <LINBus_stack.h>
// Define pin numbers for controlling power windows
#define WINDOW_FR_LEFT_PIN 6
#define WINDOW_FR_RIGHT_PIN 7
#define WINDOW_RR_LEFT_PIN 8
#define WINDOW_RR_RIGHT_PIN 9
// Instantiate LINBus_stack object
LINBus_stack linBus;
linBus.begin(19200); // Baudrate 19200
// Initialize pins for power windows
pinMode(WINDOW_FR_LEFT_PIN, OUTPUT);
pinMode(WINDOW_FR_RIGHT_PIN, OUTPUT);
pinMode(WINDOW_RR_LEFT_PIN, OUTPUT);
pinMode(WINDOW_RR_RIGHT_PIN, OUTPUT);
size_t dataLength = 0;
// Receive master request frame
if (linBus.read(receivedData, 8, &dataLength)) {
// Check if the received frame is valid and matches LIN ID for power window control
if (dataLength > 1 && receivedData[0] == LIN_ID_POWER_WINDOW) {
// Extract command
uint8_t command = receivedData[2];
// Process command based on start bit
switch (receivedData[1]) {
case 0x01: // Start bit for FR_LEFT
if (command == POWER_WINDOW_UP_CMD) {
// Move FR_LEFT power window up
digitalWrite(WINDOW_FR_LEFT_PIN, HIGH);
} else if (command == POWER_WINDOW_DOWN_CMD) {
// Move FR_LEFT power window down
digitalWrite(WINDOW_FR_LEFT_PIN, LOW);
case 0x02: // Start bit for FR_RIGHT
// Move FR_RIGHT power window up
digitalWrite(WINDOW_FR_RIGHT_PIN, HIGH);
// Move FR_RIGHT power window down
digitalWrite(WINDOW_FR_RIGHT_PIN, LOW);
case 0x03: // Start bit for RR_LEFT
// Move RR_LEFT power window up
digitalWrite(WINDOW_RR_LEFT_PIN, HIGH);
// Move RR_LEFT power window down
digitalWrite(WINDOW_RR_LEFT_PIN, LOW);
case 0x04: // Start bit for RR_RIGHT
// Move RR_RIGHT power window up
digitalWrite(WINDOW_RR_RIGHT_PIN, HIGH);
// Move RR_RIGHT power window down
digitalWrite(WINDOW_RR_RIGHT_PIN, LOW);
default:
// Invalid start bit
Your schematic is correct but I doubt you have it wired exactly that way. Have you followed @ruilviana suggestion, it worked for me.
