I have some code that I want to run on a single html page, and when you initially load the page everything looks ok, but as soon as the “Submit” button is pressed, everything goes to pot. I’m sure there must be some formatting capabilities that won’t upset the javascript, but I don’t know. Eventually these results will be sent to my YUN
So far in doing look ups for page formatting with javascript hasn’t produced beneficial results, and our own forum here doesn’t seem to use search code that stays inside the forums. you always get shunted to Google.
Any help or direction would be helpful.
Here is my code. If you run it, you’ll see what I mean:
<!DOCTYPE html>
<html>
<head>
function turnlightOn()
$('#content').load('/arduino/turnlightOn');
function turnlightOff()
$('#content').load('/arduino/turnlightOff');
</head>
<body>
<h1>Set the On Light Length </h1>
<p>Please input a number between 1 and 24 for the "On" light cycle, then click "Submit":</p>
<input id="numb" type="number">
<button type="button" onclick="myInputFunction()">Submit</button>
<p id="demo"></p>
<p id="demo1"></p>
<p id="demo2"></p>
<p id="intLightOn"></p>
<p id="intLightOff"></p>
<p id="year"></p>
<p id="hrs"></p>
<p id="min"></p>
<p id="sec"></p
var x, b, c, text, text1, text2,text3; //global variables
var startLight, stopLight;
var stopFlag = 0;
<script>
function myInputFunction() {
// Get the value of the input field with id="numb"
x = document.getElementById("numb").value;
// If x is Not a Number or less than one or greater than 24
if (isNaN(x) || x < 1 || x > 24) {
text = "Input not valid";
text = "Input is valid";
c = (24 - x); //off light cycle time
b = (24 - c); //on light cycle time
text1 = "Light on cycle is: " + (b) + " hours";
text2 = "Light off cycle is: " + (c) + " hours";
//document.getElementById("intLightOn").innerHTML = c;
//document.getElementById("intLightOff").innerHTML = b;
document.getElementById("demo1").innerHTML = text1;
document.getElementById("demo2").innerHTML = text2;
document.getElementById("demo").innerHTML = text;
</script>
<p>Time: </p>
<p>Demonstrating Year, Seconds, Minute and hours</p>
<script>
var myVar= setInterval(function(){timeFunc()}, 5000);
//var stopFlag = 0;
function timeFunc() {
var d = new Date();
document.getElementById("year").innerHTML = d;
document.getElementById("hrs").innerHTML = d.getHours();
document.getElementById("min").innerHTML = d.getMinutes();
document.getElementById("sec").innerHTML = d.getSeconds();
var h = document.getElementById("hrs").innerHTML = d.getHours();
<!-- Below "h" variable is merely a place holder at this time for my -->
<!-- Arduino start code, which will be geared for any timer type of action, such as lighting-->
<!-- 12 hour timer, 7a- 7p--all this is work in progress ATM
if (h == 7 && stopFlag == 0)
stopFlag += 1;
$('#content').load('/arduino/turnlightOn'); //start the timer and run the lights thru Arduino
else if ( h == 19 && stopFlag >= 1)
stopFlag = 0;
</script>
</body>
</html>
