APA-102 led Arduino adalight problem video added
Prismatik , Ambibox .The same problem
5v 30a psu
288 led
pin 11
pin 13
connected
I install this code
video
// Arduino interface for the use of APA-102 operated LEDs
// Uses Adalight protocol and is compatible with Boblight, Prismatik etc
// "Magic Word" for synchronisation is 'Ada' followed by LED High, Low and Checksum
#include "FastLED.h"
// Define the number of LEDs
#define NUM_LEDS 288
// Define SPI Pin. This version is using a 32u4 so pinout is different. Workst with pins 11 & 13 on the Uno.
#define DATA_PIN 11
#define CLOCK_PIN 13
// Baudrate, higher rate allows faster refresh rate and more LEDs (defined in /etc/boblight.conf)
//#define serialRate 115200
// Adalight sends a "Magic Word" (defined in /etc/boblight.conf) before sending the pixel data
uint8_t prefix[] = {'A', 'd', 'a'}, hi, lo, chk, i;
// initialise LED-array
CRGB leds[NUM_LEDS];
  FastLED.addLeds<APA102, DATA_PIN, CLOCK_PIN, BGR>(leds, NUM_LEDS);
  // initial RGB flash
  LEDS.showColor(CRGB(255, 0, 0));
  LEDS.showColor(CRGB(0, 255, 0));
  LEDS.showColor(CRGB(0, 0, 255));
  LEDS.showColor(CRGB(0, 0, 0));
//  Serial.begin(serialRate);
  Serial.print("Ada\n"); // Send "Magic Word" string to host
  // wait for first byte of Magic Word
  for(i = 0; i < sizeof prefix; ++i) {
//    waitLoop: while (!Serial.available()) ;;
    // Check next byte in Magic Word
    if(prefix[i] == Serial.read()) continue;
    // otherwise, start over
    i = 0;
//    goto waitLoop;
  // Hi, Lo, Checksum
//  while (!Serial.available()) ;;
  hi=Serial.read();
  lo=Serial.read();
  chk=Serial.read();
  // if checksum does not match go back to wait
  if (chk != (hi ^ lo ^ 0x55))
    i=0;
//    goto waitLoop;
  memset(leds, 0, NUM_LEDS * sizeof(struct CRGB));
  // read the transmission data and set LED values
  for (uint8_t i = 0; i < NUM_LEDS; i++) {
    byte r, g, b;
//    while(!Serial.available());
    r = Serial.read();
    g = Serial.read();
    b = Serial.read();
    leds[i].r = r;
    leds[i].g = g;
    leds[i].b = b;
  // shows new values
 FastLED.show();
I’m having the exact same problem.
Same code, same strips and same amount of LED’s. Doesn’t work in ambibox nor prismatik.
Did you ever find the solution?
