APC 220 antenna extension cable
I have an APC220 radio module (http://www.dfrobot.com/index.php?route=product/product&product_id=57#.UO1WBW-9a84) and it works great.
But my problem is that I need an extension cable between the module and the antenna. I bought one of these http://www.ebay.com/itm/300694819726?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649 but it doesn't fit. The pin in the middle of the cable is exposed on the wrong side so I can't crew the cable onto the radio module.
Does anyone know how do I solve this or I there a cable that fits this radio madule?
Regards
Hi danijels: Have your problem solved already? The extension cable of APC220 is coax cable with SMA connector. One end is soldered with the module. Firstly you should need remove the SMA connector on the module. If you have new requirement, pls inform me. we give the all turnkey service as you indicate how long the cable it need. my email is appconwireless at gmail. com
I had the same problem. I just ordered this and it should work just fine: http://www.ebay.com/itm/111799305393?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
