Hi to all
i hope anyone has any ideas on what might be wrong with my setup/code.
I can't seem to able to get a pair of APC220 to TX and RX and the same time using TX RX 3 on the Arduino mega.
I can get it to Radio TX data to my PC. But if i send a bit of data back using serial monitor "R" for reset no joy.
Stop the code Radio TX-ing (comment out the prints).....and it works "R" resets my code ??? :~
Strange thing is i can do both just fine simultaniusly using the USB cable ?
0 RPM 0.00 MPH 0.00 MaxMPH 10 IntBat 82 KartBat 123 Amps 66.35 Pack V 8 KW 10.94 HP 23 M Temp 00:00:05.643 Time
0 RPM 0.00 MPH 0.00 MaxMPH 10 IntBat 82 KartBat 123 Amps 66.35 Pack V 8 KW 10.94 HP 23 M Temp 00:00:05.875 Time
0 RPM 0.00 MPH 0.00 MaxMPH 10 IntBat 82 KartBat 123 Amps 66.35 Pack V 8 KW 10.94 HP 23 M Temp 00:00:06.107 Time
I would be very grateful if anyone knows any info on what might be causing this to happen.
/////TX the info to base
Serial3.print(rpm);
Serial3.print("\t");
Serial3.print("RPM");
Serial3.print(mph);
Serial3.print("MPH");
Serial3.print(MaxMPH);
Serial3.print("MaxMPH");
Serial3.print(chargedisplaypercent);
Serial3.print("IntBat");
Serial3.print(chargedisplaypercent2);
Serial3.print("KartBat");
Serial3.print(amps);
Serial3.print("Amps");
Serial3.print(PackVoltage);
Serial3.print("Pack V");
Serial3.print(KW);
Serial3.print("KW");
Serial3.print(PackVoltage * amps / 746);
Serial3.print("HP");
Serial3.print(Temp1);
Serial3.print("M Temp");
print_time(millis() - time0);
//Serial3.print(runtime);
Serial3.println("Time");
/////Heres the reading sense for letter R code/////
String input = "";
// Read any serial input
while (Serial3.available() > 0)
input += (char) Serial3.read(); // Read in one char at a time
delay(5); // Delay for 5 ms so the next char has time to be received
if (input == "R")
MaxMPH = 0;
Kind regards
James
