APDS 9960 gesture sensor
I am using APDS-9960 Gesture sensor with arduino DUE using SparkFun library but it does not seems to work.
I guess I do not need any logic converter here between sensor and due because DUE operates on 3.3V so does the gesture sensor.
This is the sensor I am using "RGB and Gesture Sensor - APDS-9960 - Proximity Detection Sensor Module"
Below is the code I am using.
#include<Wire.h>
#include<SparkFun_APDS9960.h>
#define gesture_interrupt 2
SparkFun_APDS9960 apds9960 = SparkFun_APDS9960();
volatile int interrupt_flag = 0;
 pinMode(gesture_interrupt, INPUT);
  attachInterrupt(0, interruptRoutine, FALLING);
  if(apds9960.init())
    Serial.println("FOUND APDS-9960 Module!");
    Serial.println("Can't find APDS-9960 MODULE");
  if ( apds9960.enableGestureSensor(true))
    Serial.println("Gesture sensor is enabled!");
    Serial.println("Can't start the Gesture sensor...");
  if(interrupt_flag == 1)
    detachInterrupt(0);
    handleGesture();
    interrupt_flag = 0;
void interruptRoutine()
  interrupt_flag = 1;
void handleGesture()
  if(apds9960.isGestureAvailable())
    switch(apds9960.readGesture())
      case DIR_UP:
      Serial.println("UP");
      case DIR_DOWN:
      Serial.println("DOWN");
      case DIR_LEFT:
      Serial.println("LEFT");
      case DIR_RIGHT:
      Serial.println("RIGHT");
      case DIR_NEAR:
      Serial.println("NEAR");
      case DIR_FAR:
      Serial.println("FAR");
SDA pin 20
SCL pin 21
interrupt pin 2
VCC 3.3V and GND from DUE board
Let me know if I am missing anything in the code or in the connection?
Thanks in advance.
Interrupt 0 being on pin 2 works only on ATmega328 or ATmega2560 based Arduinos. Use digitalPinToInterrupt() to translate, this should work on all supported platforms:
  attachInterrupt(digitalPinToInterrupt(2), interruptRoutine, FALLING);
