APDS-9960 with the esp8266
Hello,
I have bought the APDS-9960 a few days ago and it came today.
I wanted it to use with my project where I use the esp8266. It doesn't work with it but other arduinos work...
I used this standard code that came with it.
GestureTest.ino
APDS-9960 RGB and Gesture Sensor
Shawn Hymel @ SparkFun Electronics
May 30, 2014
https://github.com/sparkfun/APDS-9960_RGB_and_Gesture_Sensor
Tests the gesture sensing abilities of the APDS-9960. Configures
APDS-9960 over I2C and waits for gesture events. Calculates the
direction of the swipe (up, down, left, right) and displays it
on a serial console.
To perform a NEAR gesture, hold your hand
far above the sensor and move it close to the sensor (within 2
inches). Hold your hand there for at least 1 second and move it
away.
To perform a FAR gesture, hold your hand within 2 inches of the
sensor for at least 1 second and then move it above (out of
range) of the sensor.
Hardware Connections:
IMPORTANT: The APDS-9960 can only accept 3.3V!
 Arduino Pin  APDS-9960 Board  Function
 3.3V         VCC              Power
 GND          GND              Ground
 A4           SDA              I2C Data
 A5           SCL              I2C Clock
 2            INT              Interrupt
Resources:
Include Wire.h and SparkFun_APDS-9960.h
Development environment specifics:
Written in Arduino 1.0.5
Tested with SparkFun Arduino Pro Mini 3.3V
This code is beerware; if you see me (or any other SparkFun
employee) at the local, and you've found our code helpful, please
buy us a round!
Distributed as-is; no warranty is given.
#include <Wire.h>
#include <SparkFun_APDS9960.h>
// Pins
#define APDS9960_INT    2 // Needs to be an interrupt pin
// Constants
// Global Variables
SparkFun_APDS9960 apds = SparkFun_APDS9960();
int isr_flag = 0;
  // Set interrupt pin as input
  pinMode(APDS9960_INT, INPUT);
  // Initialize Serial port
  Serial.println(F("--------------------------------"));
  Serial.println(F("SparkFun APDS-9960 - GestureTest"));
  // Initialize interrupt service routine
  attachInterrupt(0, interruptRoutine, FALLING);
  // Initialize APDS-9960 (configure I2C and initial values)
  if ( apds.init() ) {
    Serial.println(F("APDS-9960 initialization complete"));
    Serial.println(F("Something went wrong during APDS-9960 init!"));
  // Start running the APDS-9960 gesture sensor engine
  if ( apds.enableGestureSensor(true) ) {
    Serial.println(F("Gesture sensor is now running"));
    Serial.println(F("Something went wrong during gesture sensor init!"));
  if( isr_flag == 1 ) {
    detachInterrupt(0);
    handleGesture();
    isr_flag = 0;
void interruptRoutine() {
  isr_flag = 1;
void handleGesture() {
    if ( apds.isGestureAvailable() ) {
    switch ( apds.readGesture() ) {
      case DIR_UP:
        Serial.println("UP");
      case DIR_DOWN:
        Serial.println("DOWN");
      case DIR_LEFT:
        Serial.println("LEFT");
      case DIR_RIGHT:
        Serial.println("RIGHT");
      case DIR_NEAR:
        Serial.println("NEAR");
      case DIR_FAR:
        Serial.println("FAR");
      default:
        Serial.println("NONE");
I only got restart messages after that.
I have tried to do it with polling, because I thought that the attachInterrupt() feature was behind it, but no that was not the case, it would not restart but also not show anything on the serial monitor...
Thanks in advance!
have same trouble and ICACHE_RAM_ATTR not helped. At usual arduino sensor works fine
