Bonjour à tous, Bonjour J.M.L.,
Je teste ce sketch écrit par J.M.L. :
KEEP THIS INFORMATION IF YOU USE THIS CODE
This "API RTE ecowatt" demo code for ESP 32 is placed under the MIT license
Copyright (c) 2022 J-M-L For the Arduino Forum
Permission is hereby granted, free of charge, to any person obtaining a copy
of this software and associated documentation files (the "Software"), to deal
in the Software without restriction, including without limitation the rights
to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
copies of the Software, and to permit persons to whom the Software is
furnished to do so, subject to the following conditions:
The above copyright notice and this permission notice shall be included in
all copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
THE SOFTWARE.
Ref : https://forum.arduino.cc/t/api-rte-ecowatt/1017281/34
#include <WiFi.h>
#include <HTTPClient.h>
#include <ArduinoJson.h>
// ! ATTENTION ELEMENTS SECRETS !
const char* ssid = "xxxxxxxxxxxx";
const char* password = "xxxxxxxxxx";
#define identificationRTE "OWZxxxxxxxxxxxxxxxxxxxx w==" // ID Client et ID Secret en base 64
const char * idRTE = "Basic " identificationRTE; // le compilateur se charge de concaténer "Basic " + ID Client et ID Secret en base 64
// le certificat racine (format PEM) de https://digital.iservices.rte-france.com
const char* root_ca = \
"-----BEGIN CERTIFICATE-----\n" \
"MIIDXzCCAkegAwIBAgILBAAAAAABIVhTCKIwDQYJKoZIhvcNAQELBQAwTDEgMB4G\n" \
"A1UECxMXR2xvYmFsU2lnbiBSb290IENBIC0gUjMxEzARBgNVBAoTCkdsb2JhbFNp\n" \
"Z24xEzARBgNVBAMTCkdsb2JhbFNpZ24wHhcNMDkwMzE4MTAwMDAwWhcNMjkwMzE4\n" \
"MTAwMDAwWjBMMSAwHgYDVQQLExdHbG9iYWxTaWduIFJvb3QgQ0EgLSBSMzETMBEG\n" \
"A1UEChMKR2xvYmFsU2lnbjETMBEGA1UEAxMKR2xvYmFsU2lnbjCCASIwDQYJKoZI\n" \
"hvcNAQEBBQADggEPADCCAQoCggEBAMwldpB5BngiFvXAg7aEyiie/QV2EcWtiHL8\n" \
"RgJDx7KKnQRfJMsuS+FggkbhUqsMgUdwbN1k0ev1LKMPgj0MK66X17YUhhB5uzsT\n" \
"gHeMCOFJ0mpiLx9e+pZo34knlTifBtc+ycsmWQ1z3rDI6SYOgxXG71uL0gRgykmm\n" \
"KPZpO/bLyCiR5Z2KYVc3rHQU3HTgOu5yLy6c+9C7v/U9AOEGM+iCK65TpjoWc4zd\n" \
"QQ4gOsC0p6Hpsk+QLjJg6VfLuQSSaGjlOCZgdbKfd/+RFO+uIEn8rUAVSNECMWEZ\n" \
"XriX7613t2Saer9fwRPvm2L7DWzgVGkWqQPabumDk3F2xmmFghcCAwEAAaNCMEAw\n" \
"DgYDVR0PAQH/BAQDAgEGMA8GA1UdEwEB/wQFMAMBAf8wHQYDVR0OBBYEFI/wS3+o\n" \
"LkUkrk1Q+mOai97i3Ru8MA0GCSqGSIb3DQEBCwUAA4IBAQBLQNvAUKr+yAzv95ZU\n" \
"RUm7lgAJQayzE4aGKAczymvmdLm6AC2upArT9fHxD4q/c2dKg8dEe3jgr25sbwMp\n" \
"jjM5RcOO5LlXbKr8EpbsU8Yt5CRsuZRj+9xTaGdWPoO4zzUhw8lo/s7awlOqzJCK\n" \
"6fBdRoyV3XpYKBovHd7NADdBj+1EbddTKJd+82cEHhXXipa0095MJ6RMG3NzdvQX\n" \
"mcIfeg7jLQitChws/zyrVQ4PkX4268NXSb7hLi18YIvDQVETI53O9zJrlAGomecs\n" \
"Mx86OyXShkDOOyyGeMlhLxS67ttVb9+E7gUJTb0o2HLO02JQZR7rkpeDMdmztcpH\n" \
"WD9f\n" \
"-----END CERTIFICATE-----\n";
const char* oauthURI = "https://digital.iservices.rte-france.com/token/oauth/";
const char* signalsURI = "https://digital.iservices.rte-france.com/open_api/ecowatt/v4/signals";
const char* signalsSandboxURI = "https://digital.iservices.rte-france.com/open_api/ecowatt/v4/sandbox/signals";
// obtention d'une transcription des codes d'erreurs spécifique à l'API RTE ou message général
String errorDescription(int code, HTTPClient& http) {
switch (code) {
case 401: return "l'authentification a échouée";
case 403: return "l’appelant n’est pas habilité à appeler la ressource";
case 413: return "La taille de la réponse de la requête dépasse 7Mo";
case 414: return "L’URI transmise par l’appelant dépasse 2048 caractères";
case 429: return "Le nombre d’appel maximum dans un certain laps de temps est dépassé";
case 509: return "L‘ensemble des requêtes des clients atteint la limite maximale";
default: break;
return http.errorToString(code);
// effectue une requête. Nécessite une connexion WiFi active.
bool getRTEData() {
String oauthPayload;
String signalsPayload;
int codeReponseHTTP;
const char* access_token;
bool requeteOK = true;
if (WiFi.status() != WL_CONNECTED) {
Serial.println("WiFI non disponible. Requête impossible");
return false;
WiFiClientSecure client;
HTTPClient http;
client.setCACert(root_ca);
http.begin(client, oauthURI);
// Specify content-type header
http.addHeader("Content-Type", "application/x-www-form-urlencoded");
http.addHeader("Authorization", idRTE);
// Send HTTP POST request
codeReponseHTTP = http.POST(nullptr, 0);
if (codeReponseHTTP == HTTP_CODE_OK) {
oauthPayload = http.getString();
Serial.println(oauthPayload);
StaticJsonDocument<192> doc;
DeserializationError error = deserializeJson(doc, oauthPayload);
if (error) {
Serial.print("deserializeJson() failed: ");
Serial.println(error.c_str());
access_token = "";
requeteOK = false;
access_token = doc["access_token"];
Serial.print("access_token : "); Serial.println(access_token);
Serial.print("erreur HTTP POST: ");
Serial.println(errorDescription(codeReponseHTTP, http));
requeteOK = false;
// on libère les resources
http.end();
if (!requeteOK) return false;
// on a récupéré l'access_token, on peut l'utiliser pour faire notre requête GET sur l'API
String signalsAutorization = "Bearer ";
signalsAutorization += String(access_token);
// si on veut tester le code sans être gêné par la limite d'un appel toutes les 15 minutes, on utilise la sandbox
// http.begin(client, signalsSandboxURI);
// si on veut avoir l'information réelle, on utilise la vraie API. On est limité à un appel toutes les 15 minutes
http.begin(client, signalsURI);
http.addHeader("Authorization", signalsAutorization.c_str());
// On envoie la requête HTTP GET
codeReponseHTTP = http.GET();
signalsPayload = http.getString();
Serial.println("----------------------");
Serial.println(" RTE JSON");
Serial.println("----------------------\n");
Serial.println(signalsPayload);
Serial.print("erreur HTTP GET: ");
Serial.print(codeReponseHTTP);
Serial.print(" => ");
Serial.println(http.errorToString(codeReponseHTTP));
requeteOK = false;
http.end();
return requeteOK;
Serial.println(); Serial.print ("Sketch : "); Serial.print ("API_RTE_ECOWATT_1.2.ino"); Serial.println();
WiFi.begin(ssid, password);
Serial.write('.');
Serial.print("\nConnected to WiFi network with IP Address: ");
getRTEData();
void loop() {}
Qui fonctionne très bien via la SandBox mais mais qui me retourne un message d'erreur lorsque je veux obtenir les valeurs du jour.
Sketch : API_RTE_ECOWATT_1.2.ino
Connected to WiFi network with IP Address: 192.168.1.50
"access_token" : "ZZqpw2qGkEk8rJ4JBx6cwoRRtpTsAwjufqFrIFeMKNrjIgpqLMebGF",
"token_type" : "Bearer",
"expires_in" : 7200
access_token : ZZqpw2qGkEk8rJ4JBx6cwoRRtpTsAwjufqFrIFeMKNrjIgpqLMebGF
erreur HTTP GET: 403 =>
qui correspond à : "l’appelant n’est pas habilité à appeler la ressource" dans l'API.
Pourtant, j'ai bien créé un compte et je récupère bien le Token en base 64.
Si quelqu'un en sait un peu plus, je suis preneur.
une autre question sur le fait que je ne récupère pas le libellé de l'erreur : erreur HTTP GET: 403 =>
J.M.L; s'il est dispo, saura surement me renseigner sur ce point ?
Merci d'avance à tous.
Fitness04
