Hello! I have 2 XBee S1's with one as the coordinator hooked up to an Arduino Uno and one as the end device connected to a pressure sensitive resistor. I am trying to send the analog signal from the one XBee to the other using API mode. I am currently using the following code:
if (Serial.available()>21){
for (int i=0; i<22; i++){
Serial.print(Serial.read(),HEX);
Serial.print(",");
The issue, however, is that the data that is printing is not consistent with what I would expect.
The first couple lines I receive are as predicted:
7E , 0 , A , 83 , 0 , 0 , 27 , 0 , 1 , 2 , 0 , 0 , F , 43
In this case from what I understand, F is my analog value from the sensor.
However, after a short period of time, the packets become much shorter:
7E , 0 , A , 83 , 0 , 24 , 2 , 55
I am not sure what is causing this issue. Possibly something with my code? Thank you!
