Full description below.
Here is the code:
#include <Servo.h> // servo library
Servo myservo1, myservo2, myservo3; // servo name
int bluetoothTx = 10; // bluetooth tx to 10 pin
int bluetoothRx = 11; // bluetooth rx to 11 pin
int motorOne = 3;
int motorOne2 = 4;
int motorTwo = 5;
int motorTwo2 = 6;
SoftwareSerial bluetooth(bluetoothTx, bluetoothRx);
//initial motors pin
char command;
char Value;
myservo1.attach(13); // attach servo signal wire to pin 9
myservo2.attach(12);
myservo3.attach(9);
//Setup usb serial connection to computer
//Setup Bluetooth serial connection to android
bluetooth.begin(9600);
while (bluetooth.available() > 0) {
Value = Serial.read();
Serial.println(Value);
if ( Value == 'F') {
// Robo Pet Run Forward
digitalWrite(motorOne, HIGH);
digitalWrite(motorOne2, LOW);
digitalWrite(motorTwo, HIGH);
digitalWrite(motorTwo2, LOW);
} else if (Value == 'B') {
//Robo Pet Run Backward
digitalWrite(motorOne, LOW);
digitalWrite(motorOne2, HIGH);
digitalWrite(motorTwo, LOW);
digitalWrite(motorTwo2, HIGH);
} else if (Value == 'L') {
//Robo Pet Turn Left
} else if (Value == 'R') {
//Robo Pet Turn Right
} else if (Value == 'S') {
//Robo Pet Stop
//Read from bluetooth and write to usb serial
if(bluetooth.available()>= 2 )
unsigned int servopos = bluetooth.read();
unsigned int servopos1 = bluetooth.read();
unsigned int realservo = (servopos1 *256) + servopos;
Serial.println(realservo);
if (realservo >= 1000 && realservo <1180) {
int servo1 = realservo;
servo1 = map(servo1, 1000, 1180, 0, 180);
myservo1.write(servo1);
Serial.println("Servo 1 ON");
delay(10);
if (realservo >= 2000 && realservo <2180) {
int servo2 = realservo;
servo2 = map(servo2, 2000, 2180, 0, 180);
myservo2.write(servo2);
Serial.println("Servo 2 ON");
delay(10);
if (realservo >= 3000 && realservo <3180) {
int servo3 = realservo;
servo3 = map(servo3, 3000, 3180, 0, 180);
myservo3.write(servo3);
Serial.println("Servo 3 ON");
delay(10);
I gathered 2 code files from Youtube. One each for the servo and motor and I combined them into one file. I am also using 2 different apps because I could not find one that works for both motor and servo control.
The app used to control the servos:
https://drive.google.com/file/d/1CMS4IN4Hxd922cu4Q6afkjA03YsoZK6r/view
The app to control the motors:
When I try using the app for the motor, there are no errors and the motors work as intended. However, when I switch to using the app to control the servos, they don’t move at all. I tested the bluetooth servo control file and there is nothing wrong. I’m a beginner programmer and don’t know exactly what I am doing wrong. Should I find an app that controls both servos and motors? Is there another way to program the servos and motors?
Let me know if there is any more info you need.
Any tips and help would be very much appreciated thank you.
