Hello everyone! I am trying to design a temperature control device for a unit on my entertainment center. The unit with my HTPC and game consoles gets hot and I have to leave the door open to try to manage temps.
The design is a pair of 12 volt fans wired to an Arduino Uno through a pair of 3205 Mosfets using a TMP 35 sensor. A 16X2 display will display temperature in celcius and farenheight on the top line and fan speeds on the bottom line.
The code is a mosaic of "borrowed" bits, examples and my personal attempts.
What I was trying to do is have the Arduino read the temperature, and have two thresholds. A lower one activates a slower, quiet fan. If temps continue to climb, the second noisier fan activates. The fans would be mapped to the temperature and controlled with PWM. I also wanted to set a "temp off" lower than the "temp on" so the fans wouldn't pulse on and off at the borderline threshold but I cut it out to try to troubleshoot.
My code, for your consideration:
#include <LiquidCrystal.h>
const int rs = 12, en = 11, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
const int sensePin = A0; // the output pin of LM35
int sensorInput;
const int fan1 = 13;
const int fan2 = 10;
const int fan1tempON = 27;
const int fan1tempMax = 70;
const int fan2tempON = 50;
const int fan2tempMax = 90;
int fan1Speed = 0;
int fan2Speed = 0;
int fan1LCD;
int fan2LCD;
double temp;
pinMode(fan1, OUTPUT);
pinMode(fan2, OUTPUT);
pinMode(sensePin, INPUT);
lcd.begin(16,2);
sensorInput = analogRead(sensePin); //read the analog sensor and store it
temp = (double)sensorInput / 1024; //find percentage of input reading
temp = temp * 5; //multiply by 5V to get voltage
temp = temp - 0.5; //Subtract the offset
temp = temp * 100; //Convert to degrees
if(temp >= fan1tempON) {
fan1Speed = map(temp, fan1tempON, fan1tempMax, 60, 255); // the actual speed of fan
fan1LCD = map(temp, fan1tempON, fan1tempMax, 0, 100); // speed of fan to display on LCD
analogWrite(fan1, fan1Speed); // spin the fan at the fanSpeed speed
if(temp >= fan2tempON) {
fan1Speed = map(temp, fan1tempON, fan1tempMax, 80, 255); // the actual speed of fan
fan2Speed = map(temp, fan2tempON, fan2tempMax, 60, 255);
fan1LCD = map(temp, fan1tempON, fan1tempMax, 0, 99); // speed of fan to display on LCD
fan2LCD = map(temp, fan2tempON, fan2tempMax, 0, 99);
analogWrite(fan2, fan2Speed);
else {
digitalWrite(fan1, LOW);
digitalWrite(fan2, LOW);
lcd.setCursor(0,0);
lcd.print("Temp:");
lcd.print(temp,1); // display the temperature
lcd.print("C ");
lcd.setCursor(11,0);
lcd.print(temp*1.8+32,1);
lcd.print("F ");
lcd.setCursor(0,1); // move cursor to next line
lcd.print("Fan1:");
lcd.print(fan1LCD); // display the fan speed
lcd.print("%");
lcd.setCursor(8, 1); // bottom right
lcd.print("Fan2:");
lcd.print(fan2LCD);
lcd.print("%");
lcd.clear();
Ive tried researching and rewriting the code, and got kinda close (I think), but it still doesn't work correctly. The temperature displays and works well. But the fans wont engage until the fan2tempON condition has been met. Also, the fan speed mapping doesn't cap at 99%. Plus, I'm sure the code is ugly...
Thanks for looking, I appreciate any help I can get!
