Applicazione socket arduino non funziona!!!!
Queste sono le due parti di codice quella di arduino e di java che dovrebbero far comunicare arduino con la mia app android. Apparte che il programma non risponde ai comandi appena il programma parte il LED dovrebbe essere spento invece rimane acceso.
Arduino:
#include <[color=#CC6600]SPI[/color].h>
#include <[color=#CC6600]Ethernet[/color].h>
[color=#CC6600]byte[/color] mac[] = { 0x90,0xA2,0xDA,0x0F,0x49,0x54 };
[color=#CC6600]byte[/color] ip[] = { 192,168,1, 10 };
[color=#CC6600]byte[/color] gateway[] = { 192,168,1,1 };
[color=#CC6600]byte[/color] subnet[] = { 255, 255, 255,0 };
[color=#CC6600]int[/color] pin=13;
[color=#CC6600]EthernetServer[/color] server(2000);
[color=#CC6600]void[/color] [color=#CC6600][b]setup[/b][/color]()
  [color=#CC6600]pinMode[/color](pin, [color=#006699]OUTPUT[/color]);
  [color=#CC6600]digitalWrite[/color](pin, [color=#006699]LOW[/color]);
  [color=#CC6600]Ethernet[/color].[color=#CC6600]begin[/color](mac, ip, gateway, subnet);
  server.[color=#CC6600]begin[/color]();
  [color=#CC6600][b]Serial[/b][/color].[color=#CC6600]begin[/color](9600);
[color=#CC6600]void[/color] [color=#CC6600][b]loop[/b][/color]()
   [color=#CC6600]EthernetClient[/color] client = server.[color=#CC6600]available[/color]();
   [color=#CC6600]char[/color] thisChar = client.[color=#CC6600]read[/color]();
    [color=#CC6600]if[/color] (client)
      [color=#CC6600]if[/color] (thisChar==[color=#006699]'0'[/color])
        [color=#CC6600]digitalWrite[/color](pin, [color=#006699]HIGH[/color]);
      [color=#CC6600]if[/color] (thisChar==[color=#006699]'1'[/color])
Android Java
package com.fexapp.ledapp;
import java.io.DataInputStream;
import java.io.DataOutputStream;
import java.io.IOException;
import java.net.Socket;
import java.net.UnknownHostException;
import android.app.Activity;
import android.os.Bundle;
import android.view.View;
import android.widget.*;
public class MainActivity extends Activity {
	Button pulsanteON,pulsanteOFF;
	public void connetti(String s)
    	Socket socket = null;
    	DataInputStream dataInputStream=null;
    	DataOutputStream dataOutputStream=null;
    	try
    		socket =new Socket("192.168.1.10",2000);
    		dataOutputStream=new DataOutputStream(socket.getOutputStream());
    		dataOutputStream.writeUTF(s);
    	catch(UnknownHostException e)
    		e.printStackTrace();
    	catch(IOException e)
    	finally
    		if(socket!=null)
    			try
    				socket.close();
    		if(dataInputStream !=null)
    			try
    				dataInputStream.close();
    		if(dataOutputStream !=null)
    			try
    				dataOutputStream.close();
	@Override
    protected void onCreate(Bundle savedInstanceState)
        super.onCreate(savedInstanceState);
        setContentView(R.layout.activity_main);
        pulsanteON =(Button) findViewById(R.id.pulsanteON);
        pulsanteOFF=(Button) findViewById(R.id.pulsanteOFF);
        pulsanteON.setOnClickListener(new View.OnClickListener() {
			@Override
			public void onClick(View v)
				String s="0";
				connetti(s);
        pulsanteOFF.setOnClickListener(new View.OnClickListener() {
			@Override
				String s="1";
				connetti(s);
mi rifiuto di analizzare una sketch in formatazione HTML. Potresti incollarlo senza ( basta fare un copia e non un esportazione dello sketch).
Ciao Uwe
DeFex_94:
Ethernet.begin(mac, ip, gateway, subnet);
Quell'inizializzazione è errata.
Quella corretta è
Ethernet.begin(mac, ip, gateway, gateway, subnet);
E quale sarebbe l'altro gateway???
Il dns.
A meno che non lo vuoi esplicitare e allora diventa.
Ethernet.begin(mac, ip, dns, gateway, subnet);
Comunque PaoloP il metodo così come me lo hai dato tu è solo un overload del metodo begin della classe Ethernet, anche perchè in un'altra prova che ho fatto circa 2 o 3 giorni fa non mi ha mai dato problemi se omettevo il gateway....piuttosto non riesco a capire perchè mi rimane il led acceso sebbene all'inizio del programma gli dico di rimanere spento. bho??? pareri ben accetti....grazie
Per il LED ci potrebbe essere una carica residua che lo mantiene acceso. E' successo altre volte.
Riguardo alla Ethernet, devi seguire i metodi della libreria scelti dallo sviluppatore della stessa, non quelli che piacciono. (a meno di non modificare la libreria)
Se passi i parametri
stai passando come gateway l'indirizzo 255.255.255.0.
Il fatto è che funziona come server, ma non puoi andare all'esterno come client perché i parametri di rete sono errati.
Poi sono d'accordo sul fatto che l'inizializzazione così fatta non è per niente intuitiva, ma è quella richiesta.
Sto andando in confusione ma 255.255.255.0 non sarebbe la subnet??? il gateway ho passato 192.168.1.1 quello della wifi.
Comunque penso di aver capito dove stava il problema del LED poi qualcuno mi confermi se è così:
la scheda usa il pin 13 e alcuni altri per comunicare con la shield ethernet e sta di fatto che il pin(in questo casoil 13) diventava inutilizzabile....adesso utilizzo il pin 9 e il led parte da spento ma la comunicazione tra il cellulare android e la scheda non avviene ancora se qualcuno è in grado di aiutarmi mi dia una mano sto preparando un lavoro per un esame e ho bisogno di capire come risolvere....grazie
Ma adesso Arduino è nella rete ? Quali parametri dai come IP/dns/gateway/etc. ?
Quale scheda di rete ? La ufficiale con WIZ5100 o quella clone con l'ENC ?
In java questo che fa il secondo parametro? E' la porta ?
Se 2000 è la porta UDP, l'hai aperta sul router ?
P.S. nel primo post modifica e togli quella serie di colori, non si capisce una fava. Grazie
Ho la scheda originale;
IP:192.168.1.10 ->ne ho scelto uno di libero sulla rete
gateway e subnet-> ho inserito quelli della scheda wifi che vedo tramite ipconfig dal mio cmd
MAC adress->quello della scheda arduino
dns-> non so cosa mettere
comunque vi do il link che ho seguito
Comunque il socket è 2000 e il router o l'access point a casa mia son bloccati da password quindi non posso aprire o chiudere la porta....non ci sono altri modi???
dns metti 8.8.8.8 che è quello di google.
Da qui sembra che il secondo parametro è la porta, quindi 2000 è la porta
http://docs.oracle.com/javase/7/docs/api/java/net/Socket.html
secondo me la porta deve essere aperta.
ho inserito il dns ma il LED non si accende ancora
Altre soluzioni???
Ho appena verificato con un software che si chiama "Advance Port scanner" per vedere le varie porte aperte su gli indirizzi IP e la porta 2000 nell'indirizzo di IP di arduino non risulta essere aperta non si può risolvere direttamente da arduino invece che dal router???
Di solito no. Esisto apparecchi che usando UPnP riescono ad aprirsi le porte, ma: 1.questo UPnP deve essere abilitato sul router. 2.Arduino non è un dispositivo UPnP
Se qualsiasi apparecchio potesse "manipolare" le porte del router, senza password, sai quanti virus ti beccheresti ? :grin:
Sempre che sia così importante aprire la porta 2000. Non ne ho la certezza. Non conosco quei comandi Java socket.
ma qualsiasi numero di porta che inserisco devo aprirlo dal router......se usassi la porta 80 per esempio non mi lascerebbe???
Credo di si, quella di solito è aperta. Anche la 21 dovrebbe (usata da FPT)
Vedo la porta aperta ora ma il LED non riesco ad accenderlo......non so più come fare???
