Apply filter to signal
I'd like to use a built-in function to apply a pass-band butterworth filter to gyro and accelerometer signals.
In the "base" version of my sketch I computed the transfer function coefficients through Matlab and imported in IDE and used a function to apply the filter to my signal.
IMU.readAcceleration(ax, ay, az);
filtered = butterworthBandpassFilter(az);
float butterworthBandpassFilter(float input) {
  // Shift previous inputs and outputs
  for (int i = 10; i > 0; i--) {
    x[i] = x[i-1];
    y[i] = y[i-1];
  // Set the new input value
  x[0] = input;
  // Apply the filter equation: y[n] = sum(b[i]*x[n-i]) - sum(a[i]*y[n-i])
  float output = 0;
  for (int i = 0; i < 11; i++) {
    output += b[i] * x[i];
    if (i > 0) {
      output -= a[i] * y[i];
  // Store the output value
  y[0] = output;
  return output;
where, input is my raw signal, a and b the two vectors containing the filter coefficients, x and y two variables to support the computations (initialized to 0)
// Filter coefficients (from matlab script: 0.1-0.49 Hz)
float b[21] =  {0.00931683037284933, 0,	-0.0931683037284933,	0,	0.419257366778220,	0,	-1.11801964474192,	0,	1.95653437829836,	0,	-2.34784125395803,	0,	1.95653437829836,	0,	-1.11801964474192,	0,	0.419257366778220,	0,	-0.0931683037284933,	0,	0.00931683037284933};
float a[21] = {1,	7.70916073863389,	26.2193801260813,	52.9090893787506,	74.1857165778666,	83.2831166956718,	82.1591744709078,	69.9143748679608,	48.9193599755739,	29.4495226454652,	16.5180734695797,	7.91051329362060,	2.83326241996057,	0.956145139883915,	0.374057155228569,	0.0703549907427079,	-0.00271358318385719,	0.00614164964651132,	0.00136790282939128,	-0.000653542477654263,	8.73430659265187e-05};
// Filtered values (state variables)
float x[21] = {0};  // Input history
float y[21] = {0};  // Output history
The problem with this approach is that if I want to change the sampling or cutoff frequency, coefficients change and I need to calculate them first in Matlab, then copy-paste in the sketch.
I found this repository with functions to compute the the transfer function but I don't understand how to extract coefficients that I need.
The best would be find a function that works the same as Matlab's "butter" and "filter" or "filtfilt" functions. I found a function that says doing this job but it misses the .h file and I don't know how to write it to make it work or convert it to be usable in IDE.
Do you have any alternative/ideas to do this job?
As your topic does not relate directly to the installation or operation of the IDE it has been moved to the Programming category of the forum
