Applying millis in my code
For a school project i'm working on menu that only uses slide potmeters. This is a requirement and we are not allowed to use any other electronics.
The project is a calculator with multiple formula's, if you want to take a look follow to link.
My school project.
For the selection of the menu i made the following code
if ((potM0 <= 0)&&(potM1 <= 0)&&(potM2 <= 0)) {
  lcd.clear();
  menu--;
  tekst1 = 0;
I made multiple IF statements that are linked to the menu variable.
Now my problem is that when all the potmeters are on zero the menu goes back, but i don't want that to happen because then i can never calculate the lowest number. What i want is to add a layer so the menu only changes when the following happens:
-all sliders on the lowest
-timer start
-slider 1 down and up
-Did this happen between an x amount of time?
-yes, menu changes
-no, menu stays the same
I am told to do this with millis and i tried but i can't seem to figure it out.
With kind regards,
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27,20,4);
int menu = 0;
int potM0 =A0;
int potM1 =A1;
int potM2 =A2;
int tekst1 =0;
unsigned long startMillis;
byte Vierkant[8] = {
  0b00000,
  0b11111,
  0b11111,
  0b11111,
  0b11111,
  0b11111,
  0b00000,
  0b00000
byte Cirkel[8] = {
  0b00000,
  0b01110,
  0b11111,
  0b11111,
  0b11111,
  0b01110,
  0b00000,
  0b00000
byte Driehoek[8] = {
  0b00000,
  0b00100,
  0b00100,
  0b01110,
  0b01110,
  0b11111,
  0b11111,
  0b00000
//.......................Formule 1............................................................
float a, b, c, r, gr, bo, A, B, C;
float calculatie(float X, float Y, float Z)
  float R;
  gr = X/2;
  bo = Y/2;
  R = (PI*Z*(sq(gr)+sq(bo)+(gr)*(bo)))/3;
  return R;
//.......................Formule 2............................................................
float ab, hb, ob, stb, Ab;
float calculatieHoogte(float Xb)
  float Hb;
  stb=Xb/2;
  Hb = 1000000/(PI*sq(stb));
  return Hb;
float calculatieOppervlakte(float Xb)
  float Ob;
  stb=Xb/2;
  Ob = 2*PI*stb*(stb+(1000000/(PI*sq(stb))));
  return Ob;
//.......................Formule 3............................................................
float ac, rc, dc, Ac;
float calculatie(float Xc)
  float Rc;
  dc = ((-7172.00*sq(Xc)+717200.00*Xc+80371225.00)/2209.00);
  Rc = (((-143440.00-640.00*Xc)/8836.00)-sqrt(dc))/(-4386.00/2209.00);
  return Rc;
//.......................Formule 4......................................
float ad, wd, kd, afd, Ad;
float maximaleWrijving(float Xd)
  float Wd;
  afd=Xd/100.00;
  Wd = 313.92-(533.664/sqrt(16.00+sq(afd)));
  return Wd;
float horizontaleKracht(float Xd)
  float Kd;
  afd=Xd/100.00;
  Kd = (333.54*afd)/sqrt(16.00+sq(afd));
  return Kd;
//...............Formule 5..........................................
float ae, be, ce, re, Ae, Be, Ce;
float calculatiee(float Xe, float Ye, float Ze)
  float Re;
  float dte = 0.1;
  float ge  = 9810;
  while (Ze>0) {
    Ze=Ze-(sq(Xe)/sq(Ye))*dte*sqrt(2*ge*Ze);
    Re = Re+dte;
  return Re;
//Welkom tekst
  void scrolling_loop1()
   String text = "Schuif alle sliders naar omhoog om naar de volgende formule te gaan";
   int i, j=0;
  for (i =0; i<text.length(); i++)
      if(i<19)
          lcd.setCursor(i,1);
          lcd.print(text.charAt(i));
          delay(150);
           for(i=20;i<text.length();i++)
               j++;
               lcd.setCursor(0,1);
               lcd.print(text.substring(j,j+20));
             delay(250);
  void scrolling_loop2()
   String text = "Schuif alle sliders naar omlaag om terug naar de vorige formule te gaan";
   int i, j=0;
      if(i<19)
          lcd.setCursor(i,1);
          delay(150);
               j++;
               lcd.setCursor(0,1);
             delay(250);
  void scrolling_loop3()
   String text = "Het volume van een afgeknotte kegel";
   int i, j=0;
      if(i<19)
          lcd.setCursor(i,2);
          delay(150);
               j++;
               lcd.setCursor(0,2);
             delay(250);
  void scrolling_loop4()
   String text = "Cilindrisch volume verpakking";
   int i, j=0;
      if(i<19)
          lcd.setCursor(i,2);
          delay(150);
               j++;
               lcd.setCursor(0,2);
             delay(250);
  void scrolling_loop5()
   String text = "     Kabelbaan";
   int i, j=0;
      if(i<19)
          lcd.setCursor(i,2);
          delay(150);
               j++;
               lcd.setCursor(0,2);
             delay(250);
  void scrolling_loop6()
   String text = "     Trekkabel";
   int i, j=0;
      if(i<19)
          lcd.setCursor(i,2);
          delay(150);
               j++;
               lcd.setCursor(0,2);
             delay(250);
  void scrolling_loop7()
   String text = "  Leegstromend vat";
   int i, j=0;
      if(i<19)
          lcd.setCursor(i,2);
          delay(150);
               j++;
               lcd.setCursor(0,2);
             delay(250);
void scrolling_loop8()
   String text = "De kosten van 3D printen";
   int i, j=0;
      if(i<19)
          lcd.setCursor(i,2);
          delay(150);
               j++;
               lcd.setCursor(0,2);
             delay(250);
//.......................Formule 5......................................
  lcd.init();
  lcd.backlight();
  lcd.setCursor(4,1);
  lcd.print("Welkom in de");
  lcd.setCursor(1,2);
  lcd.print("Custom calculator!");
  delay(2000);
  lcd.clear();
  //lcd.setCursor(7,0);
  //lcd.print("Uitleg");
  //scrolling_loop1();
 // delay(1000);
  //lcd.clear();
  //scrolling_loop2();
  //delay(1000);
  //lcd.clear();
  potM0 = map(analogRead(A0), 0, 1023, 0, 50);
  potM1 = map(analogRead(A1), 0, 1023, 0, 50);
  potM2 =map(analogRead(A2), 0, 1023, 0, 50);
//if ((potM0 >= 50)&&(potM1 >=50)&&(potM2>=50)) {
  //lcd.clear();
 // menu++;
 // tekst1 = 0;
  //delay(1000);
if ((potM0 >= 50)&&(potM1 >=0)&&(potM2>=50)) {
  lcd.clear();
  menu = 10 ;
  tekst1 = 0;
  millis();
  if (((potM0 >= 50)&&(potM1 >=50)&&(potM2>=50)) && (millis <= 500)){
    lcd.clear();
      menu++;
     tekst1 = 0;
     //delay(1000);
  lcd.clear();
  menu--;
  tekst1 = 0;
if(menu==-1){
  menu =0;
if (menu==0){
  if(tekst1==0){
  lcd.setCursor(5,1);
  lcd.print("Formule 1");
  scrolling_loop3();
  delay(2000);
  lcd.clear();
  tekst1++;
  a = map(analogRead(A0), 0, 1023, 0, 50);
  lcd.createChar(0, Vierkant);
  lcd.setCursor(0,0);
  lcd.write((byte)0);
  lcd.setCursor(2,0);
  lcd.print("Diameter1=");
  lcd.print(a,0);
  b = map(analogRead(A1), 0, 1023, 0, 25);
  lcd.createChar(1, Cirkel);
  lcd.setCursor(0,1);
  lcd.write((byte)1);
  lcd.setCursor(2,1);
  lcd.print("Diameter2=");
  lcd.print(b,0);
  c = map(analogRead(A2), 0 , 1023, 0, 100);
  lcd.createChar(2, Driehoek);
  lcd.setCursor(0,2);
  lcd.write((byte)2);
  lcd.setCursor(2,2);
  lcd.print("Hoogte=");
  lcd.print(c,0);
  r = calculatie(a,b,c);
  lcd.setCursor(2,3);
  lcd.print("Volume=");
  lcd.print(r,2);
  A = a;
  B = b;
  C = c;
  if (a != A)
    lcd.setCursor(12,0);
    lcd.print("  ");
    lcd.print(a,0);
    lcd.setCursor(9,3);
    lcd.print("         ");
    lcd.setCursor(9,3);
    lcd.print(r,2);
    A = a;
  if (b != B)
    lcd.setCursor(12,1);
    lcd.print("  ");
    lcd.print(b,0);
    lcd.setCursor(9,3);
    lcd.print("         ");
    lcd.setCursor(9,3);
    lcd.print(r,2);
    B = b;
  c = map(analogRead(A2), 0, 1023, 0, 100);
  if (c != C)
    lcd.setCursor(9,2);
    lcd.print("   ");
    lcd.setCursor(9,2);
    lcd.print(c,0);
    lcd.setCursor(9,3);
    lcd.print("         ");
    lcd.setCursor(9,3);
    lcd.print(r,2);
    C = c;
else if (menu==1){
  if(tekst1==0){
  lcd.setCursor(5,1);
  lcd.print("Formule 2");
  scrolling_loop4();
  delay(2000);
  lcd.clear();
  tekst1++;
  ab = map(analogRead(A0), 0, 1023, 75, 125);
  lcd.setCursor(0,0);
  lcd.write((byte)0);
  lcd.setCursor(2,0);
  lcd.print("Diameter=");
  lcd.print(ab,0);
  hb = calculatieHoogte(ab);
  lcd.setCursor(2,1);
  lcd.print(hb,2);
  ob = calculatieOppervlakte(ab);
  lcd.setCursor(2,2);
  lcd.print("Oppervlak=");
  lcd.print(ob,2);
  Ab = ab;
  if (ab != Ab)
    lcd.setCursor(11,0);
    lcd.print("   ");
    lcd.print(ab,0);
    lcd.setCursor(9,1);
    lcd.print("           ");
    lcd.setCursor(9,1);
    lcd.print(hb,2);
    lcd.setCursor(12,2);
    lcd.print("     ");
    lcd.print(ob,2);
    Ab = ab;
else if (menu==2){
    if(tekst1==0){
  lcd.setCursor(5,1);
  lcd.print("Formule 3");
  scrolling_loop5();
  delay(2000);
  lcd.clear();
  tekst1++;
  ac = map(analogRead(A0), 0.00, 1023.00, 0.00, 1000.00);
  lcd.setCursor(0,0);
  lcd.write((byte)0);
  lcd.setCursor(2,0);
  lcd.print("X = ");
  lcd.print(ac/10.00,1);
  rc = calculatie(ac/10.00);
  lcd.setCursor(2,1);
  lcd.print("Y = ");
  lcd.print(rc,7);
  Ac = ac;
  ac = map(analogRead(A1), 0.00, 1023.0, 0.00, 1000.00);
  if (ac != Ac)
    lcd.setCursor(6,0);
    lcd.print("     ");
    lcd.setCursor(6,0);
    lcd.setCursor(6,1);
    lcd.print("          ");
    lcd.setCursor(6,1);
    lcd.print(rc,7);
    Ac = ac;
//.......................Formule 4.......................................................
else if (menu==3){
      if(tekst1==0){
  lcd.setCursor(5,1);
  lcd.print("Formule 4");
  scrolling_loop6();
  delay(2000);
  lcd.clear();
  tekst1++;
  ad = map(analogRead(A0), 0.00, 1023.00, 0.00, 500.00);
  lcd.setCursor(0,0);
  lcd.write((byte)0);
  lcd.setCursor(2,0);
  lcd.print("x    = ");
  lcd.print(ad,0);
  wd = maximaleWrijving(ad);
  lcd.setCursor(2,1);
  lcd.print("Fmax = ");
  lcd.print(wd,2);
  kd = horizontaleKracht(ad);
  lcd.setCursor(2,2);
  lcd.print("Fhor = ");
  lcd.print(kd,2);
  Ad = ad;
  if (ad != Ad)
    lcd.setCursor(9,0);
    lcd.print("   ");
    lcd.setCursor(9,0);
    lcd.print(ad,0);
    lcd.setCursor(9,1);
    lcd.print("      ");
    lcd.setCursor(9,1);
    lcd.print(wd,2);
    lcd.setCursor(9,2);
    lcd.print("      ");
    lcd.setCursor(9,2);
    lcd.print(kd,2);
    Ad = ad;
//.......................Formule 5.......................................................
else if (menu==4){
      if(tekst1==0){
  lcd.setCursor(5,1);
  lcd.print("Formule 5");
  scrolling_loop7();
  delay(2000);
  lcd.clear();
  tekst1++;
  ae = map(analogRead(A0), 0, 1023, 5, 50);
  lcd.setCursor(0,0);
  lcd.write((byte)0);
  lcd.setCursor(2,0);
  lcd.print(ae,0);
  be = map(analogRead(A1), 0, 1023, 400, 800);
  lcd.setCursor(0,1);
  lcd.write((byte)1);
  lcd.setCursor(2,1);
  lcd.print(be,0);
  ce = map(analogRead(A2), 0 , 1023, 500, 1000);
  lcd.setCursor(0,2);
  lcd.write((byte)2);
  lcd.setCursor(2,2);
  lcd.print(ce,0);
  lcd.setCursor(2,3);
  lcd.print("Tijd=");
  re = calculatiee(ae,be,ce);
  lcd.print(re,0);
  lcd.setCursor(13,3);
  lcd.print("sec.");
  Ae = ae;
  Be = be;
  Ce = ce;
  if (ae != Ae)
    lcd.print("  ");
    lcd.print(ae,0);
    lcd.setCursor(7,3);
    lcd.print("     ");
    lcd.setCursor(7,3);
    lcd.print(re,0);
    Ae = ae;
  if (be != Be)
    lcd.print("  ");
    lcd.print(be,0);
    lcd.setCursor(7,3);
    lcd.print("     ");
    lcd.setCursor(7,3);
    lcd.print(re,0);
    Be = be;
  ce = map(analogRead(A2), 0, 1023, 500, 1000);
  if (ce != Ce)
    lcd.setCursor(9,2);
    lcd.print("    ");
    lcd.setCursor(9,2);
    lcd.print(ce,0);
    lcd.setCursor(7,3);
    lcd.print("     ");
    lcd.setCursor(7,3);
    lcd.print(re,0);
    Ce = ce;
else if (menu==5){
  if(tekst1==0){
  lcd.setCursor(2,1);
  lcd.print(" Eigen opdracht");
  scrolling_loop8();
  delay(2000);
  lcd.clear();
  tekst1++;
  lcd.setCursor(0,1);
  lcd.print("hier komt de opdracht");
else if (menu==10){
  lcd.setCursor(3,0);
  lcd.print("Gemaakt door:");
  lcd.setCursor(4,1);
  lcd.print("Stefan kars");
  lcd.setCursor(0,2);
  lcd.print("Camile Zaadnoordijk");
  lcd.setCursor(4,3);
  lcd.print("Abe Reinsma");
“I am told to do this with millis and i tried but i can't seem to figure it out.”
Show us the complete sketch.
I added it the the post
can you explain (without code) how you plan to use the sliders?
To change variables. If you take a look at the sketch is will al make mutch more sense.
First, have you determined that each of the potentiometers will actually go to zero and go to a maximum value. Will they all go to zero and the same maximum or will you have to process each as an individual pot?
