approach for comms over RF Transmitter & Recei
BACKGROUND:
I'm seeking some advice re how to approach communications between remote Arduino units that have an RF Transmitter (MO-SAWR-A, http://www.sparkfun.com/datasheets/Wireless/General/MO-SAWR.pdf), with the single base Arduino unit that has an RF Receiver (MO-RX3400-A http://www.sparkfun.com/datasheets/Wireless/General/MO-RX3400.pdf). Apparently the way they work is that what the transmitter 'sees' on its data pin is what the receiver outputs on its data pin
QUESTIONS:
a) Should I just be looking as treating them as a serial connection perhaps?
b) If yes then would the best library to use be the one here http://arduino.cc/en/Reference/SoftwareSerial? (I note there is also the following libraries however I'm not sure they're appropriate: Wire - Arduino Reference, Arduino Playground - SerialControl)
c) Or in fact, noting the fact that the slave remote unit is just collecting door closed/open event and using the RF Tx/Rx to get this back to the master unit, could I just connect the output pin to the transmitter input. Then the open/closed signal is effectively sent back and could be used by the master no? But would this approach be a bit of a battery drain on the slave remote detector Ardunio unit perhaps.
d) Anyone know of an article/blog that specifically addresses using these RF Tx and Rx with Arduino units?
thanks
@Richard - thanks. This makes sense. Re your last paragraph you don't happen to know which library might already provide these type of capabilities?
Isn't this exactly what the VirtualWire library is for?
thanks - I'll look into it
I didn't see it listed at http://arduino.cc/en/Reference/Libraries, but I see it now in the long list of links at Arduino playground
