I have two RFM95 Lora radios (915mhz). I have them in LOS about 30 metres away and I am using the following settings:
frequency = 915E6;
tx power = 20;
spread factor = 12;
bandwidth = 125E3;
coding denom = 5;
Both radios have 915mhz aerials connected.
I am currently getting an RSSI of -95 and an SNR of 3. Is this about what I should expect? Appreciate that it varies on other conditions but would be good to know that its about right.
First reason is it is too long for 915 mHz. Second is at 868, is has 2DBi gain which in reality is an actual loss of 1 dbi compared to a dipole antenna with 3dbi gain.
Paul
Much easier when trying to work out if an RF device is working well or is not is to use a basic antenna, i.e. a bit of wire that is 1/4 wavelength long at the appropriate frequency.
Any other comparision depends on the purchased antenna being what it claims to be and the only way to be sure of that is to use an antenna tester and then a field test to verify the radiation pattern.
A simple bit of wire of the right length is going to perform more or less the same for everyone, the wire type is not critical, and its a universal comparison standard.
