Arabic Font?
may you help me please to know from where can i get Arabic font for DMD?
i have 16X32 DMD and its working fine with English ,but i hope if i can display Arabic font.
thanks in advance.
Code
#include <SPI.h> //SPI.h must be included as DMD is written by SPI (the IDE complains otherwise)
#include <DMD.h> //
#include <TimerOne.h> //
#include "SystemFont5x7.h"
#include "Arial_black_16.h"
//Fire up the DMD library as dmd
#define Budrate 9600
#define DISPLAYS_ACROSS 2
#define DISPLAYS_DOWN 1
DMD dmd(DISPLAYS_ACROSS, DISPLAYS_DOWN);
Interrupt handler for Timer1 (TimerOne) driven DMD refresh scanning, this gets
called at the period set in Timer1.initialize();
void ScanDMD()
dmd.scanDisplayBySPI();
setup
Called by the Arduino architecture before the main loop begins
void setup(void)
//initialize TimerOne's interrupt/CPU usage used to scan and refresh the display
Timer1.initialize( 5000 ); //period in microseconds to call ScanDMD. Anything longer than 5000 (5ms) and you can see flicker.
Timer1.attachInterrupt( ScanDMD ); //attach the Timer1 interrupt to ScanDMD which goes to dmd.scanDisplayBySPI()
dmd.clearScreen( true ); //true is normal (all pixels off), false is negative (all pixels on)
Serial.begin(Budrate);
void loop(void)
dmd.selectFont(Arial_Black_16);
String content = "";
char character;
while(Serial.available())
character = Serial.read();
content.concat(character);
// delay (10);
if (content != "")
Serial.println(content);
char *txt;
txt=&content[0];
for (byte x=0;x<DISPLAYS_ACROSS;x++) {
for (byte y=0;y<DISPLAYS_DOWN;y++) {
if(content.length()==6)
dmd.drawString( 5, 1+(16y), txt,content.length(), GRAPHICS_NORMAL );
if(content.length()==5)
dmd.drawString( 10, 1+(16
else if(content.length()==4)
dmd.drawString( 15, 1+(16y), txt,content.length(), GRAPHICS_NORMAL );
//Ahmed rememeber that MEssage must be more or = 7 Char.
else if(content.length()>=7)
dmd.drawMarquee(txt,content.length(),(32
DISPLAYS_ACROSS)-1,0);
long start=millis();
long timer=start;
boolean ret=false;
while(!ret){
if ((timer+30) < millis()) {
ret=dmd.stepMarquee(-1,0);
timer=millis();
delay( 500 );
maybe there is something here:
(I can't read it, hopefully I have not linked to something naughty!)
thanks Peter
it's not Arabic font , but thanks peter for your help.
Is Arabic a 'letter' based language? If so you are importing what appears to be a couple of font files. Have a look at those to see if you can create your own font?
Thanks Dannable
dannable:
It is, and there is a set of ASCII codes for the letters:
http://www.ascii.ca/iso8859.6.htm
