Hi everyone,
I'm new in using Arbotix-M
i have following the guide from http://learn.trossenrobotics.com/arbotix/arbotix-quick-start.html
but when im starting to uploading ArbotiXBlink, i get this one,
avrdude: stk500_getsync(): not in sync: resp=0x00
i try to search to solve this problem but i dont get the solution.
im using Arbotix-M with FTDI module (E FTDI) FT232RL.
and using Arduino v1.05 and i try v1.06 too.
I'm following the guide carefully and exact as the guide says.
Please help me and please provide any information that you guys know
How sure are you you select the right COM port? Have you verified it with the Device Manager? Please post a screenshot.
Very sure, cause only 1 COM PORT showed up, in my laptop only COM 6 if i use the FTDI ... the FTDI is COM 6
jasongosal:
Hi everyone,
You have to replace your board. This error means that your board is not being able to communicate with the controller.
:o Another one?
https://forum.arduino.cc/index.php?topic=522764.0
I'd suspect the bootloader is missing.
