Arc cosine function not functioning as expected. what am i missing?
Howdy everyone!
does anyone know why acsos(.50); returns 1.05
hers the code:
#include <math.h>
double input = 40;
double input2 =80;
double out;
Serial.println(input);
Serial.println(input2);
out = input / input2;
Serial.println(out);
out = acos(out);
ans serial output
80.00
0.50
1.05
thanks guys!
–isaac
Well, it should return 1.047197, so I guess to two decimal places, 1.05 is close enough.
(You are remembering we work in radians?)
LOL that would explain it. Is there a function in math.h that converts these values into degrees? Im trying to use this for controlling servos. thanks!
--Isaac
CodeNewton: Is there a function in math.h that converts these values into degrees?
Well it's easy enough to multiply by 57.3....
The values (that you input to acos()) are in degrees. They need to be in radians. There are 2 PI radians in 360 degrees, so a little math is all that is needed. Write your own function...
The output of the acos function is in radians. The input is a number from -1 to +1.
Pete
Sounds easy enough. I'll write one:) Why would I need to change the ratio passed to acos into radians? Thanks --isaac
You don't. I was think of sin() and cos() when I wrote that rubbish.
