Ardbot ii Code
I’m trying to get the code for the Ardbot ii robot to work. I’ve downloaded the zip file from the website, and I put the IR Remote folder inside the Arduino Libraries folder. When I open the code, I click ‘Sketch’ → ‘Include Library’ → ‘Robot IR Remote’ and this pastes
#include <IRremote.h>
#include <IRremoteInt.h>
#include <IRremoteTools.h>
above the existing code. When I click ‘Verify’ I get the following error (the part with the ****** is my name):
/Users/********/Downloads/Arduino.app/Contents/Java/libraries/RobotIRremote/src/IRremoteTools.cpp:5:16: error: 'TKD2' was not declared in this scope
 int RECV_PIN = TKD2; // the pin the IR receiver is connected to
Error compiling.
So, I’m not sure what I’m doing wrong, and how I need to fix it. Any help at all is appreciated!
I'm trying to get the code for the Ardbot ii robot to work.
Is that an official Arduino robot? If not, delete the code that fails to compile.
The usual fix for that issue (if you want to use IRRemote, is to delete the
RobotIRremote
library folder....unless of course thats actually what you want to use.
