Ardino uno error uploding
#include <IRremote.h>
int recvPin = 2;
IRrecv irrecv(recvPin);
void setup ()
Serial.begin(9600); // Status message will be sent to PC at 9680 baud
irrecv.enableIRIn(); // Start the receiver
// Display IR code
void ircode (decode_results *results){
if (results->decode_type == PANASONIC) {
Serial.print(results->address, HEX);
Serial.print(":");
THIS IS MY CODE
Arduino: 1.8.15 (Windows Store 1.8.49.0) (Windows 10), Board: "Arduino Uno"
C:\Users\POORANI\AppData\Local\Temp\ccB9q6fb.ltrans0.ltrans.o: In function `main':
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\cores\arduino/main.cpp:46: undefined reference to `loop'
collect2.exe: error: ld returned 1 exit status
Multiple libraries were found for "IRremote.h"
Used: C:\Users\POORANI\Documents\Arduino\libraries\IRremote
Not used: C:\Users\POORANI\Documents\Arduino\libraries\IRremote-3.3.0
Not used: C:\Users\POORANI\Documents\Arduino\libraries\arduino_635252
exit status 1
Error compiling for board Arduino Uno.
option enabled in File -> Preferences.
THIS IS MY ERROR
CAN ANYONE HELP ME WITH THIS PROJECT FOR AN IR HEX CODE RECIVER
Check out this thread:
how do i deal with multiple libraries installed? - Using Arduino / Programming Questions - Arduino Forum
Read it carefully, I don't think the other user got the full benefit of the instructions.
Hi, @kanishk_developer
Welcome to the forum.
Please read the post at the start of any forum , entitled "How to use this Forum".
It will show how to post your code in a scrolling window.
Thanks for posting your error message, it helps a lot. :+1:
Tom... :smiley: :+1: :coffee: :australia:
Seems like you have not implemented the lop function:
// add require code here.
I think you meant:
  if (ircode (decode_results *results)
      Serial.print(":");
      Serial.println("Not PANASONIC.");
