Ardiono GPRS http command not responding properly
I am using arduino uno with itead 3G shield , my shield works fine but it doesn’t responding properly ,
After sendint
“AT+chttpact =…” it back me +CHTTPACT: REQUEST then when it send GET command it doesn’t response at all
What could be the problem ??
here the real response and the code :
GSM : Registered to network
GSM : Ready for AT command
*** Start HTTP Transaction ***
+CHTTPACT: REQUEST
AT+CHTTPACT=“jsonplaceholder.typicode.com”,80
Sends Request:
GET /posts/1/ HTTP/1.1
Host:jsonplaceholder.typicode.com:80
Content-Length:0
*** End HTTP Transaction ***
Memory Free : 1216
Code :
// Included header files
#include <SoftwareSerial.h>
// AT command related
#define AT_CREG_QUERY ("AT+CREG?")
#define AT_CHTTPACT_COMMAND ("AT+CHTTPACT=\"%s\",%d")
#define AT_CHTTPACT_INIT_RESPONSE ("+CHTTPACT: REQUEST")
#define AT_CHTTPACT_DATA_RESPONSE ("+CHTTPACT: DATA,")
#define AT_CHTTPACT_DONE_RESPONSE ("+CHTTPACT:0")
#define EOS ('\0')
#define ESC (0x1A)
#define OK ("OK")
// GSM definitions
#define unoTXPin (7) // Uno -> GSM
#define unoRXPin (6) // Uno <- GSM
#define powerGSMPin (8)
#define GSMBaudRate (9600)
#define UnoBaudRate (9600)
SoftwareSerial gsmSerial(unoRXPin,unoTXPin);
#define TEST_REQUEST ("GET /posts/1/ HTTP/1.1\r\nHost:jsonplaceholder.typicode.com:80\r\nContent-Length:0\r\n\r\n")
char aux_str [100];
int8_t answer;
int aux = 0;
int data_size = 0;
#define HOST_NAME ("jsonplaceholder.typicode.com")
#define HOST_PORT (80)
  // init sequence
  Serial.begin(UnoBaudRate);
  gsmSerial.begin(UnoBaudRate);
  gsm_power_on();
  while( (sendATcommand(AT_CREG_QUERY, "+CREG: 0,1", 500) ||
    sendATcommand(AT_CREG_QUERY, "+CREG: 0,5", 500)) == 0 );
  Serial.println(F("GSM : Registered to network"));
  Serial.println(F("GSM : Ready for AT command"));
void loop () {
    sprintf(aux_str, AT_CHTTPACT_COMMAND, HOST_NAME, HOST_PORT);
    Serial.println(F("\n*** Start HTTP Transaction ***\n"));
    Serial.println(AT_CHTTPACT_INIT_RESPONSE);
    answer = sendATcommand(aux_str, AT_CHTTPACT_INIT_RESPONSE, 60000);
    Serial.println(aux_str);
    if (answer == 1)
      data_size = 0;
      Serial.println(F("Sends Request:"));
      Serial.println(TEST_REQUEST);
      gsmSerial.println(TEST_REQUEST);
      // Sends
      aux_str[0] = ESC;
      aux_str[1] = 0x00;
      answer = sendATcommand(aux_str, AT_CHTTPACT_DATA_RESPONSE, 300000);
      if(answer == 1)
        Serial.println(AT_CHTTPACT_DATA_RESPONSE);
          while(gsmSerial.available() > 0) {
            Serial.print((char)gsmSerial.read());
      Serial.println(F("\n*** End HTTP Transaction ***\n"));
      Serial.print(F("Memory Free : "));
      Serial.println(memoryFree());
      while(1); // halt
// variables created by the build process when compiling the sketch
extern int __bss_end;
extern void *__brkval;
// function to return the amount of free RAM
int memoryFree(){
  int freeValue;
  if((int)__brkval == 0)
    freeValue = ((int)&freeValue) - ((int)&__bss_end);
    freeValue = ((int)&freeValue) - ((int)__brkval);
  return freeValue;
void gsm_power_on(){
  uint8_t answer=0;
  // checks if the module is started
  answer = sendATcommand("AT", "OK", 2000);
  if (answer == 0)
    // power on pulse
    digitalWrite(powerGSMPin,HIGH);
    delay(200);
    digitalWrite(powerGSMPin,LOW);
    delay(6000);
    // waits for an answer from the module
    while(answer == 0){
      // Send AT every two seconds and wait for the answer
      answer = sendATcommand("AT", OK, 2000);
int8_t sendATcommand(char* ATcommand, char* expected_answer1,
unsigned int timeout)
  uint8_t x=0,  answer=0;
  char response[100];
  unsigned long previous;
  memset(response, EOS, 100);    // Initialize the string
  delay(100);
  while( gsmSerial.available() > 0) gsmSerial.read();    // Clean the input buffer
  gsmSerial.println(ATcommand);    // Send the AT command
    x = 0;
  previous = millis();
  // this loop waits for the answer
  do{
    if(gsmSerial.available() != 0){
      response[x] = gsmSerial.read();
      x++;
      // check if the desired answer is in the response of the module
      if (strstr(response, expected_answer1) != NULL)
        answer = 1;
    // Waits for the asnwer with time out
  while((answer == 0) && ((millis() - previous) < timeout));
  return answer;
int8_t sendATcommand2(char* ATcommand, char* expected_answer1,
char* expected_answer2, unsigned int timeout)
  char response[100];
  delay(100);
    x = 0;
  do{
      x++;
        answer = 1;
      if (strstr(response, expected_answer2) != NULL)
        answer = 2;
  return answer;
Please read #7 below:
http://forum.arduino.cc/index.php/topic,148850.0.html
