Ardiuno Camcorder Control
I am having F5000 mini camcorder,i want to turn the camera and recording at a particular time by making use of ardiuno
How can i do this ?
Your support is needed
If you don't want to open the case you could use a servo to push the record button.
If you don't mind opening the case and soldering to the internal circuits you could use a small relay or CMOS bi-lateral switch to parallel the record button.
