Ardiuno Processor
I am new to this but need the Inclinometer project to work for me.
I connect the USB cable and try to upoad some LED's flash but I get an error "Uploading Error"
I have connected the processor board - but no green LED. With switch in OFF or ON position
Bootstrap ? Cannot do this.
Really need some help.
Thanks
Really need some detail
Please do this:
  • File > Preferences > Show verbose output during: > compilation (uncheck) > upload (check) > OK
  • Sketch > Upload
  • After the upload fails you’ll see a button on the right side of the orange bar “Copy error messages”. Click that button.
  • Paste the error messages in a reply here USING CODE TAGS (</> button on the toolbar).
Some questions
Which "inclinometer project"?
Which operating system.
Which IDE version?
Which Arduino are you using?
What does Windows device manager (or Linux/Mac equivalents) say when you connect and disconnect the board?
Which switch are you referring to? Arduinos usually don't have a switch, only a reset button.
Without knowing the board, most Arduinos (maybe all) have a power led. If that does not come on when you connect the board to the PC, you have either a broken board or a faulty USB cable.
Thank you for the reply here are the boards:-
TinyDuino Processor ASM2001-R-L
TinyShield USB ASD2101 R
TinyShield 7 Segment Display ASD2421-R
TinyShield Accelerometer ASD2511-R
Windows 7 professional pc 64 bit operating system
I would like to use the USB to power the system at present so should switch on processor be ON or OFF
and this is what I am trying to make
Arduino: 1.8.7 (Windows 7), Board: "Arduino/Genuino Uno"
avrdude: Version 6.3-20171130
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM15
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x39
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x39
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x39
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x39
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x39
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x39
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x39
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x39
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x39
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x39
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
Your board is not an Uno.
According to step 6 in TinyDuino - TinyCircuits, you need to select Arduino Pro or Pro Mini.
Next select the 3.3V / 8MHz 328P under tools -> processor.
Thanks so much
All Working
Brilliant !
