ardiuno unwanted rounding rounding
this is part of a program i been working i broken program in parts to work of the bugs.
i have is unwanted rounding which i do not know how to fix
here is and example of the problem
double example = 730532 + .49961;
Serial.print("example ");
Serial.print(example,12);
serial prints out 730532.5
i should get this 730532.49961
i have been getting this throught the calculation
i need exact number
int xPOS, yPOS;
int yearA = 2018;
int monthA = 9;
int dayA = 19;
int t_zone=0;
int summer=0;
int hourA=5;
int minA=48;
int secA=0;
int lmst_hour, lmst_min, lmst_sec;
int last_hour, last_min, last_sec;
double lmst, last;
int RA_HH,RA_MM,RA_SS;
int long_DD = -78;
int long_MM = 45;
int long_SS = 45;
int lat_DD = 39;
int lat_MM = 39;
int lat_SS = 10;
int count;
void setup(){
// while(!Serial);
// gps.begin(9600);
//gpsSerial.begin(9600);
// delay(1000);
void loop(){
while (gpsSerial.available()>0) {
gps.encode(gpsSerial.read());
if (gps.location.isUpdated()){
Serial.print("Latitude= ");
Serial.println(gps.location.lat(), 6);
Serial.print(" Longitude= ");
Serial.println(gps.location.lng(), 6);
if (gps.encode(gpsSerial.read())) {
Serial.print("Number os satellites in use = ");
Serial.println(gps.satellites.value());
hourA = gps.time.hour();
minA = gps.time.minute();
secA = gps.time.second();
SiderealTime();/
LCD.clear();
LCD.setCursor(0,1);
LCD.print("DATE");
LCD.setCursor(7,1);
LCD.print(monthA);
LCD.setCursor(9,1);
LCD.print(dayA);
LCD.setCursor(13,1);
LCD.print(yearA);
LCD.setCursor(0,1);
LCD.print("TIME HOUR MIN SEC");
LCD.setCursor(0,2);
LCD.print("DEC");
LCD.setCursor(8,2);
LCD.print(last_hour); //DEC Degrees
LCD.setCursor(13,2);
LCD.print(last_min);
LCD.setCursor(14,2);
LCD.print(last_sec);
LCD.setCursor(0,3);
LCD.print("RA");
LCD.setCursor(8,3);
LCD.print(hourA);
LCD.setCursor(13,3);
LCD.print(minA);
LCD.setCursor(14,3);
LCD.print(secA);*/
int SiderealTime(){
t_zone = 0; //longitude / 15; //time zone
double L_time = (hourA + (minA / 60.0000 ) + (secA / 3600.0000)); // decimal hours
double GMT = (L_time + t_zone - summer) / 24.0000; // greenwich medredian time
int YY = int((monthA + 9) / 12);
double AA = int(7*(yearA+YY));
double BB = int(AA / 4);
double CC = int(275.0000000 * monthA / 9.0000000);
double XX= 367.0000000 * yearA;
double SS = XX - BB + CC + dayA;
double JD=SS - 730532 .49961 + GMT;
Serial.print("JD ");
Serial.println(JD,8);
double j_cent = JD / 36525.0000000; // julian centuries to J2000
Serial.print("j_cent ");
Serial.println(j_cent,8);
double EE = 360.98564736629 * JD;
Serial.print("EE ");
Serial.println(EE,12);
double FF = 280.46061837 + EE;
Serial.print("FF ");
Serial.println(FF,12);
double gmst=fmod((FF), 360);
Serial.print("gmst ");
Serial.println(gmst,8); //longitude of the ascending node of the Moon's mean orbit - the longitude when the Moon passes through the plane of the ecliptic
double Om = fmod((280.46061837+360.98564736629j_cent), 360);
double Sun_long = fmod((280.4665+36000.7698
j_cent), 360); //mean longitude of the Sun
double Moon_long = fmod((218.3165+481267.8813*j_cent), 360); //mean longitude of the Moon
//change in the ecliptic longitude of a star due to the nutation (good to about 0.5 arcsec)
double dp =-17.2sin(Om)-1.32sin(2Sun_long)-0.23sin(2Moon_long)+0.21sin(2Om);
//shift in angle between the ecliptic and equator (good to about 0.1 arcsec)
double de =9.2
cos(Om)+0.57cos(2Sun_long)+0.1cos(2Moon_long)-0.09cos(2Om);
double eps =23.43929111-46.815/60/60*j_cent; // Obiliquity of the Ecliptic
double dT=(dp / PI *180)*cos(de+eps)/3600; //difference between Mean and Apparent Sidereal Times
double gast=gmst+dT;// Greenwich Apparent Sidereal Time
lmst=gmst+longitude; //local Mean sidereal time
last=gast+longitude; //local Apparent sidereal time
lmst_hour = int(lmst/15);
lmst_min=int((lmst/15-lmst_hour)*60);
lmst_sec=int(lmst/15-lmst_hour-lmst_min/60)*3600;
last_hour = int(last/15);
last_min=int((last/15-last_hour)*60);
last_sec=(last/15-last_hour-lmst_min/60)*3600;
i am using mega 2560
Floating point numbers (floats, doubles) are never accurate, sorry.
Work with integers and integer math if you need accuracy.
// Edit
PS
Double is equivalent to float on AVR based boards.
sterretje:
Right, both float and double are the same 32-bit IEEE format in AVR. You're getting as good as you're going to get with that format.
Even of you were using a processor that supports 64 bit doubles, like the Arm on the Due, you'd be hard-pressed to get twelve places of decimals.
Please remember to use code tags when posting code.
