Ardiuno with 2 RX/TX serial IO
Hi, I'm relatively new to working Arduinos.
I am currently working on a project that collects sensor data and sends to a comp. via Bluetooth the data and the location (using a GPS reciever module) .
I have a Duemilanove with only 1 RX/TX port, and I think I would need two (GPS and Bluetooth).
So do I need to get an Arduino that has two of these?
Thanks.
No, you can use a software emulated serial port to read a GPS. Search for NewSoftSerial.
EDIT - You can do either function with NSS; I chose GPS because you will likely find in usage that it fits emulation better than BlueTooth.
check out the software serial library
http://www.arduino.cc/en/Tutorial/SoftwareSerial
