Hi all,
In a future project i'd like to be abled to read DMX values (so, as a receiver/slave, not as master) with a Arduino, using a MAX485 IC.
I've found the following code which seems to be very usefull:
https://playground.arduino.cc/DMX/Ardmx
But, as this device should be abled to change it's DMX startadress, i'd like to introduce a small OLED i2c display with a rotary potentiometer to set the start adress.
For example with this library: SSD1306Ascii
Is it possible to use these both together? Isn't there going to be any problems to the double serial usage (1 for reading DMX and 1 for communicating with the i2c protocol)?
I'd like to use a Arduino Nano for this by the way.
Looking forward to your replies!
