Ardruio using Adafruit 7-segment display
I'm developing a product using a NodeMCU esp8266 with an Adafruit 7-segment display. Yesterday, it was compiled. Today, without any changes to the source file I got the following error,
/home/builder/opt/libraries/latest/adafruit_led_backpack_library_1_3_1/Adafruit_LEDBackpack.cpp:695:6: error: prototype for 'void Adafruit_7segment::writeDigitNum(uint8_t, uint8_t, boolean)' does not match any in class 'Adafruit_7segment'
void Adafruit_7segment::writeDigitNum(uint8_t d, uint8_t num, boolean dot) {
In file included from /home/builder/opt/libraries/latest/adafruit_led_backpack_library_1_3_1/Adafruit_LEDBackpack.cpp:38:0:
/home/builder/opt/libraries/latest/adafruit_led_backpack_library_1_3_1/Adafruit_LEDBackpack.h:376:8: error: candidate is: void Adafruit_7segment::writeDigitNum(uint8_t, uint8_t, bool)
void writeDigitNum(uint8_t x, uint8_t num, bool dot = false);
/home/builder/opt/libraries/latest/adafruit_led_backpack_library_1_3_1/Adafruit_LEDBackpack.cpp:726:6: error: prototype for 'void Adafruit_7segment::writeDigitAscii(uint8_t, uint8_t, boolean)' does not match any in class 'Adafruit_7segment'
void Adafruit_7segment::writeDigitAscii(uint8_t d, uint8_t c, boolean dot) {
Cool! A good error message. +.5.
Could you post the well formatted code in code tags?
Did the library update overnight?
What was the last thing you changed?
The only thing I can see that might be a conflict is the difference between 'bool' and 'boolean'.
In Adafruit_LEDBackpack.h (line 376) the function is declared:
But in Adafruit_LEDBackpack.cpp (line 695) the function is declared:
Similarly for writeDigitAscii.
I think 'bool' and 'boolean' are supposed to be the same but I'm not sure how they could end up different, unless someone defines a macro.
try a short demo sketch - just the initialization of the display and one single "print".
Does it work?
If not - post this example sketch in code tags so we can check it.
Additionally - please note which ESP core Version have you installed.
P.S.: some time ago I made a Library for HT16K33 based displays. It provides the common "print" interface. You might give it a try:
https://werner.rothschopf.net/201909_arduino_ht16k33.htm
