ArduBlock is it really any good?
I am new at programing my Arduino I have made a program that will fade 2 leds 1 from 0 to 255 and the other will fade 5 points every time the first led hit 20. The c program works great but when I make the program with ArduBlock it will not run. Both program look the same other then the way ArduBlock lays it out. I am wondering if it is a waste of time using ArduBlock and just stick with learning c++
Here is a copy of both programs and a screen print of the ArduBlock layout.
Just looking for some input on if the ArduBlock is wrong in some way or if I should stick with the c++ programing.
The c++ program:
Fade
This example shows how to fade an LED on pin 9 and 10
using the analogWrite() function.
This example code is in the public domain.
int led = 9; // the pin that the LED is attached to
int led2 = 10;
int brightness = 0; // how bright the LED is
int bri2 = 0;
int fadeAmount = 5; // how many points to fade the LED by
int fade = 5;
// the setup routine runs once when you press reset:
// declare pin 9 to be an output:
pinMode(led, OUTPUT);
pinMode(led2,OUTPUT);
// the loop routine runs over and over again forever:
// set the brightness of pin 9 and 10:
analogWrite(led, brightness);
analogWrite(led2,bri2);
//Serial.println(fade);
Serial.println(bri2);
if (brightness == 20){
bri2 = bri2 + fade;
if (bri2 == 0 || bri2 == 255){
fade = -fade ;
// change the brightness for next time through the loop:
brightness = brightness + fadeAmount;
if (brightness == 0 || brightness == 255) {
fadeAmount = -fadeAmount ;
// wait for 30 milliseconds to see the dimming effect
delay(30);
The ArduBlock version:
int _ABVAR_1_led = 0 ;
int _ABVAR_2_led2 = 0 ;
int _ABVAR_3_brightness = 0 ;
int _ABVAR_4_bri2 = 0 ;
int _ABVAR_5_fadeamount = 0 ;
int _ABVAR_6_fade = 0 ;
pinMode( _ABVAR_1_led , OUTPUT);
pinMode( _ABVAR_2_led2 , OUTPUT);
_ABVAR_1_led = 9 ;
_ABVAR_2_led2 = 10 ;
_ABVAR_4_bri2 = 0 ;
_ABVAR_5_fadeamount = 5 ;
_ABVAR_6_fade = 5 ;
analogWrite(_ABVAR_1_led , _ABVAR_3_brightness);
analogWrite(_ABVAR_2_led2 , _ABVAR_4_bri2);
Serial.print(_ABVAR_4_bri2);
Serial.print(_ABVAR_3_brightness);
if (( ( _ABVAR_3_brightness ) == ( 20 ) ))
_ABVAR_4_bri2 = ( _ABVAR_4_bri2 + _ABVAR_6_fade ) ;
if (( ( ( _ABVAR_4_bri2 ) == ( 0 ) ) || ( ( _ABVAR_4_bri2 ) == ( 255 ) ) ))
_ABVAR_6_fade = ( _ABVAR_6_fade - _ABVAR_6_fade ) ;
_ABVAR_3_brightness = ( _ABVAR_3_brightness + _ABVAR_5_fadeamount ) ;
if (( ( ( _ABVAR_3_brightness ) == ( 0 ) ) || ( ( _ABVAR_3_brightness ) == ( 255 ) ) ))
_ABVAR_5_fadeamount = ( _ABVAR_5_fadeamount - _ABVAR_5_fadeamount ) ;
delay( 100 );
I'm not surprised it doesn't work, looking at this line:
Honestly, i'd ditch the graphical programming and just learn Arduino-C - Arduino C is kind of "easy mode C" so to speak, and ArduBlock seems to generate ghastly code.
Two different names for the same pin number, eh? And, the hardware serial pin, to boot.
I'm with the others. ArduBlock is useless.
Thanks for the help. I am going to drop the ArduBlock and just learn c in a lot of ways it is a lot faster and a lot easier to read and follow then ArduBlock. At this time I really see no real use for it .
And find c more suited for my needs. Thank again for the feed back.
