ArduCAM mini save bmp to microSD card- corrupted data.
I’m having issues trying to get my Arducam mini with OV2640 sensor to interface with an SD card. The camera communicates with the Arducam PC app well, however I’d like to run it as a timelapse straight through the Arduino Uno without needing to intervene with a PC. I’ve set up code to capture the data to the Arducam buffer, to generate and name the bmp file on the SD, and to transfer the data to the SD based on the Arducam mini examples, another post on this forum (//http://forum.arduino.cc/index.php?topic=285778.0) and the Adafruit Serial Camera libraries.
// inspired by http://sauerwine.blogspot.fr/2013/07/an-arduino-time-lapse-camera-using.html
// and http://www.arducam.com/how-arducam-use-a-external-trigger-from-a-sensor/
#include <UTFT_SPI.h>
#include <SD.h>
#include <Wire.h>
#include <ArduCAM.h>
#include <SPI.h>
#include "memorysaver.h"
#include <avr/pgmspace.h>
#include <ov2640_regs.h>
// pin 11 = MOSI, pin 12 = MISO, pin 13 = SCK
#define BMPIMAGEOFFSET 54
#define SD_CS 9
const int CS1 = 4;
// Constants that define the format of the picture taken
const int bmp_mode = 0;
const int mode = bmp_mode;
const char bmp_header[54] PROGMEM =
      0x42, 0x4D, 0x36, 0x58, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x36, 0x00, 0x00, 0x00, 0x28, 0x00,
      0x00, 0x00, 0x40, 0x01, 0x00, 0x00, 0xF0, 0x00, 0x00, 0x00, 0x01, 0x00, 0x10, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x58, 0x02, 0x00, 0xC4, 0x0E, 0x00, 0x00, 0xC4, 0x0E, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00
// Instanciation of the class ArduCAM
ArduCAM myCAM1(OV2640, CS1);
// Used in takePicture() to transfer the buffer of the ArduCAM into a BMP file
void writeBMP(File outFile){
  char VH, VL;
  uint8_t temp,temp_last;
  int i, j, posn, nextNum;
    //Write the BMP header
  for( i = 0; i < 54; i++)
    char ch = pgm_read_byte(&bmp_header[i]);
    outFile.write((uint8_t*)&ch,1);
  //Read the first dummy byte from FIFO
  temp = myCAM1.read_fifo();
  //Read 320x240x2 byte from FIFO
  for(i = 0; i < 240; i++)
    for(j = 0; j < 320; j++)
      VH = myCAM1.read_fifo();
      VL = myCAM1.read_fifo();
      //RGB565 to RGB555 Conversion
      if (false) {
        VL = (VH << 7) | ((VL & 0xC0) >> 1) | (VL & 0x1f);
        VH = VH >> 1;
      //Write image data to file
      outFile.write(VL);
      outFile.write(VH);
// IMAGE FILE GENERATION
// generates a name and returns the opened file
File imageFile(){
 // generates the filename
 char filename[13];
File outFile;
  strcpy(filename, "IMAGE00.BMP");
  for (int i = 0; i < 100; i++) {
    filename[5] = '0' + i/10;
    filename[6] = '0' + i%10;
    // create if does not exist, do not open existing, write, sync after write
    if (! SD.exists(filename)) {
   Serial.println(filename);
 // opens the file
 outFile = SD.open(filename,O_WRITE | O_CREAT | O_TRUNC);
 if (! outFile){
 Serial.println("open file failed");
 Serial.println("File opened sucessfully");
 return outFile;
// ========= TAKE PICTURE ========
// simple to use function, which takes a picture
// either in JPEG (bugged) or BMP format in function
// of the 'mode' constant
void takePicture(){
  Serial.println("Taking picture...");
  File outFile;
  uint8_t start_capture = 0;
  myCAM1.write_reg(ARDUCHIP_MODE, 0x00);
  // Initialisation
  // Warning : if you use set_format(JPEG) before Init, it will freeze
  myCAM1.set_format(BMP);
  Serial.print("Init ? ");
  myCAM1.InitCAM();
  Serial.println("OK");
  myCAM1.flush_fifo(); // clean ArduCAM buffer
  myCAM1.clear_fifo_flag(); // start capture
  myCAM1.start_capture();
  Serial.print("Waiting for capture..."); //waiting until capture is done
  while (!(myCAM1.read_reg(ARDUCHIP_TRIG) & CAP_DONE_MASK)) {
   delay(10);
  // open a file onto the SD card
  outFile = imageFile();
    // writes the content of the ArduCAM buffer into the file, with the right
    // function, defined by the 'mode' value
    Serial.print("Buffering...");
    writeBMP(outFile);
    // close the file and clean the flags and the buffers
    outFile.close();
    Serial.println("Capture finished");
    start_capture = 0;
    myCAM1.InitCAM();
// Function that waits for n seconds, writing a countdown on the Serial console
void countdown(int n = 10){
 while (n>0){
    Serial.print(n);
    Serial.println("... ");
    n=n-1;
// ======== SETUP ========
void setup(){
  uint8_t vid,pid;
  uint8_t temp;
  #if defined (__AVR__)
    Wire.begin();
  #endif
  #if defined(__arm__)
    Wire1.begin();
  #endif
  // begins the Serial communication
  Serial.println("ArduCAM Start!");
  pinMode(CS1, OUTPUT);
  SPI.begin();
  myCAM1.write_reg(ARDUCHIP_TEST1, 0x55);
  temp = myCAM1.read_reg(ARDUCHIP_TEST1);
  if(temp != 0x55)
   Serial.println("SPI interface Error!");
   while(1);
  else {
  Serial.println("SPI All Good");
  // change MCU mode (?)
  myCAM1.InitCAM();
  // SD card initialisation
  if (!SD.begin(SD_CS))
    while (1); //If failed, stop here
    Serial.println("SD Card Error");
 {   Serial.println("SD Card detected!");
void loop(){
 takePicture();
 delay(20000);
The script seems to run fine, and I get the correct series of messages on the COM:
ArduCAM Start!
SPI All Good
SD Card detected!
Taking picture...
Init ? OK
Waiting for capture...OK
Buffering...OK
Capture finished
However, when I check the saved file , the pixel data is corrupted (see IMAGE00).
Arducam have listed a known issue with the Rev C sheild (on which the mini is based) and Arduino Due based on the comparative speeds of the Arducam chip and SD card over the SPI bus that they recommend solving by reducing the speed in the SD header files (http://www.arducam.com/arducam-arduino-due-board/), so I thought I’d give this a go. By increasing the denominator to 4 and not opening the COM , I get slightly better data (see IMAGE01). Going to five or six decreases the quality again.
Can anyone give me some insight as to what’s going wrong, or any tips on what I could try to fix the stray pixels?
Thanks in advance.
I have similar issue with 5MP version of the arducam mini, but saving the BMP into a normal SD card, by the use of your code (adapted to my camera model, of course). I know that the camera works, because i am able to save the files in my pc, and to have images from the camera on real time by a image capture program.
Were you able to solve it? If so, could you share here your solution? Thanks!
